[Swift-devel] trunk execution fails with absolute path
Ketan Maheshwari ketancmaheshwari at gmail.com
Mon Aug 26 20:31:52 CDT 2013
Just a note that I tested the same configuration with 0.94 which works.
On Mon, Aug 26, 2013 at 8:28 PM, Ketan Maheshwari <
ketancmaheshwari at gmail.com> wrote:
> Hi,
> I notice the execution fails in trunk when providing absolute path for a
> file. I tested this with a catsn example. When providing relative path, it
> works. The mode is coasters, local:slurm on midway.
> Error message is as follows:
> Execution failed:
> Exception in cat:
>     Arguments:
> [__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/data.txt]
>     Host: midway
>     Directory: catsn-20130827-0122-c0vppi56/jobs/d/cat-dpf6fdel
>     exception @ swift-int-staging.k, line: 159
> Caused by: Job failed with and exit code of 1
> org.globus.cog.abstraction.impl.common.execution.JobException: Job failed
> with and exit code of 1 (exit code: 1)
>     at
> org.globus.cog.abstraction.coaster.service.local.JobStatusHandler.requestComplete(JobStatusHandler.java:40)
>     at
> org.globus.cog.coaster.handlers.RequestHandler.receiveCompleted(RequestHandler.java:88)
>     at
> org.globus.cog.coaster.channels.AbstractCoasterChannel.handleRequest(AbstractCoasterChannel.java:527)
>     at
> org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.stepNIO(AbstractStreamCoasterChannel.java:238)
>     at
> org.globus.cog.coaster.channels.NIOMultiplexer.loop(NIOMultiplexer.java:97)
>     at
> org.globus.cog.coaster.channels.NIOMultiplexer.run(NIOMultiplexer.java:56)
> Caused by: org.globus.cog.abstraction.impl.common.execution.JobException:
>     at
>     at
>     at
>     at
>     at
>     at
> Log for this run is:
> http://www.mcs.anl.gov/~ketan/absolutepath.log
> Thanks for any suggestions on fixing this.
> Regards,
> Ketan
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130826/c0c14520/attachment.html>
