[Swift-devel] tests changes
Mihael Hategan
hategan at mcs.anl.gov
Tue Aug 27 10:54:01 CDT 2013
The local dir was the default when running suite.sh in tree mode (-t).
It is how I test non-trivial changes. Compile, cd tests, ./suite.sh -t
groups/group-all-local. That should work whether or not it is used for
the wider battery of tests.
Mihael
On Tue, 2013-08-27 at 10:11 -0500, Yadu Nand wrote:
> Hi Mike, Mihael,
> David and I had discussed this last week, and we came to the conclusion
> that since they
> are not being run regularly in the test-suite they maybe be obsolete. I am
> now running
> sanity tests and IO tests regularly which test most of these functionality.
> I had moved the
> sites specific configs to the sites/todo folder, for reference.
> I could add all of these deleted content back into either the todo folder
> or a pending folder.
> Please let me know what you would prefer.
> I see how deleting those files before checking with the group was a
> mistake. Sorry about that.
> Thanks,
> -Yadu
> On Tue, Aug 27, 2013 at 9:34 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> > Indeed, we should query swift-devel before making changes with potential
> > negative impact (like removing or deprecating features, tests, docs etc).
> > Regarding the tests removed: all the clusters there are still active.
> > Maybe just move ones for which the tests are not yet usable to "pending/"
> > or similar?
> > Im not sure why beagle, local, local-coaster were on the list?
> > - Mike
> > ----- Original Message -----
> > > From: "Mihael Hategan" <hategan at mcs.anl.gov>
> > > To: "Swift Devel" <swift-devel at ci.uchicago.edu>
> > > Sent: Monday, August 26, 2013 10:35:04 PM
> > > Subject: [Swift-devel] tests changes
> > > https://trac.ci.uchicago.edu/swift/changeset/6909
> > > But I use local all the time!
> > > Please don't remove just because something is not used in one
> > > particular
> > > case. Remove only if something is not used at all.
> > > Mihael
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Hi Mike, Mihael,
> conclusion that since they
> I am now running
> functionality. I had moved the
> folder or a pending folder.
> Thanks,
> -Yadu
> potential negative impact (like removing or deprecating
> active. Maybe just move ones for which the tests are not yet
> usable to "pending/" or similar?
> - Mike
> one
> > particular
> > Mihael
> Yadu Nand B
