[Swift-devel] tests changes
Yadu Nand
yadudoc1729 at gmail.com
Tue Aug 27 10:11:34 CDT 2013
Hi Mike, Mihael,
David and I had discussed this last week, and we came to the conclusion
that since they
are not being run regularly in the test-suite they maybe be obsolete. I am
now running
sanity tests and IO tests regularly which test most of these functionality.
I had moved the
sites specific configs to the sites/todo folder, for reference.
I could add all of these deleted content back into either the todo folder
or a pending folder.
Please let me know what you would prefer.
I see how deleting those files before checking with the group was a
mistake. Sorry about that.
-Yadu
On Tue, Aug 27, 2013 at 9:34 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Indeed, we should query swift-devel before making changes with potential
> negative impact (like removing or deprecating features, tests, docs etc).
> Regarding the tests removed: all the clusters there are still active.
> Maybe just move ones for which the tests are not yet usable to "pending/"
> or similar?
> Im not sure why beagle, local, local-coaster were on the list?
> - Mike
> > From: "Mihael Hategan" <hategan at mcs.anl.gov>
> > To: "Swift Devel" <swift-devel at ci.uchicago.edu>
> > Sent: Monday, August 26, 2013 10:35:04 PM
> > Subject: [Swift-devel] tests changes
> > https://trac.ci.uchicago.edu/swift/changeset/6909
> > But I use local all the time!
> > Please don't remove just because something is not used in one
> > particular
> > case. Remove only if something is not used at all.
> > Mihael
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Yadu Nand B
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130827/4ba209c8/attachment.html>
