[Swift-devel] tests changes
Yadu Nand yadudoc1729 at gmail.com
Tue Aug 27 11:38:02 CDT 2013
Hi Mihael,
Are any tests failing for you when you run ./suite.sh -t
groups/group-all-local ?
It is working for me on both trunk and 0.94.1-RC2 and that pretty much runs
every night.
Are there any other groups that you run ?
-Yadu
On Tue, Aug 27, 2013 at 10:54 AM, Mihael Hategan <hategan at mcs.anl.gov>wrote:
> The local dir was the default when running suite.sh in tree mode (-t).
> It is how I test non-trivial changes. Compile, cd tests, ./suite.sh -t
> groups/group-all-local. That should work whether or not it is used for
> the wider battery of tests.
> Mihael
> On Tue, 2013-08-27 at 10:11 -0500, Yadu Nand wrote:
> > Hi Mike, Mihael,
> > David and I had discussed this last week, and we came to the conclusion
> > that since they
> > are not being run regularly in the test-suite they maybe be obsolete. I
> am
> > now running
> > sanity tests and IO tests regularly which test most of these
> functionality.
> > I had moved the
> > sites specific configs to the sites/todo folder, for reference.
> > I could add all of these deleted content back into either the todo folder
> > or a pending folder.
> > Please let me know what you would prefer.
> > I see how deleting those files before checking with the group was a
> > mistake. Sorry about that.
> > Thanks,
> > -Yadu
> > On Tue, Aug 27, 2013 at 9:34 AM, Michael Wilde <wilde at mcs.anl.gov>
> wrote:
> > > Indeed, we should query swift-devel before making changes with
> potential
> > > negative impact (like removing or deprecating  features, tests, docs
> etc).
> > > Regarding the tests removed: all the clusters there are still active.
> > > Maybe just move ones for which the tests are not yet usable to
> "pending/"
> > > or similar?
> > > Im not sure why beagle, local, local-coaster were on the list?
> > > - Mike
> > > ----- Original Message -----
> > > > From: "Mihael Hategan" <hategan at mcs.anl.gov>
> > > > To: "Swift Devel" <swift-devel at ci.uchicago.edu>
> > > > Sent: Monday, August 26, 2013 10:35:04 PM
> > > > Subject: [Swift-devel] tests changes
> > > > https://trac.ci.uchicago.edu/swift/changeset/6909
> > > > But I use local all the time!
> > > > Please don't remove just because something is not used in one
> > > > particular
> > > > case. Remove only if something is not used at all.
> > > > Mihael
> > > > _______________________________________________
> > > > Swift-devel mailing list
> > > > Swift-devel at ci.uchicago.edu
> > > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> > Hi Mike, Mihael,
> > conclusion that since they
> > I am now running
> > functionality. I had moved the
> > folder or a pending folder.
> > Thanks,
> > -Yadu
> >         potential negative impact (like removing or deprecating
> >          features, tests, docs etc).
> >         active. Maybe just move ones for which the tests are not yet
> >         usable to "pending/" or similar?
> >         - Mike
> >         one
> >         > particular
> >         > Mihael
> > Yadu Nand B
Yadu Nand B
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130827/f95aaace/attachment.html>
