[Swift-devel] tests changes
Michael Wilde
wilde at mcs.anl.gov
Tue Aug 27 09:34:42 CDT 2013
Indeed, we should query swift-devel before making changes with potential negative impact (like removing or deprecating features, tests, docs etc).
Regarding the tests removed: all the clusters there are still active. Maybe just move ones for which the tests are not yet usable to "pending/" or similar?
Im not sure why beagle, local, local-coaster were on the list?
- Mike
----- Original Message -----
> From: "Mihael Hategan" <hategan at mcs.anl.gov>
> To: "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Monday, August 26, 2013 10:35:04 PM
> Subject: [Swift-devel] tests changes
> https://trac.ci.uchicago.edu/swift/changeset/6909
> But I use local all the time!
> Please don't remove just because something is not used in one
> particular
> case. Remove only if something is not used at all.
> Mihael
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
