[Swift-devel] trunk execution fails with absolute path
Ketan Maheshwari ketancmaheshwari at gmail.com
Mon Aug 26 20:28:09 CDT 2013
I notice the execution fails in trunk when providing absolute path for a
file. I tested this with a catsn example. When providing relative path, it
works. The mode is coasters, local:slurm on midway.
Error message is as follows:
Execution failed:
Exception in cat:
    Arguments:
[__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/data.txt]
    Host: midway
    Directory: catsn-20130827-0122-c0vppi56/jobs/d/cat-dpf6fdel
    exception @ swift-int-staging.k, line: 159
Caused by: Job failed with and exit code of 1
org.globus.cog.abstraction.impl.common.execution.JobException: Job failed
with and exit code of 1 (exit code: 1)
    at
org.globus.cog.abstraction.coaster.service.local.JobStatusHandler.requestComplete(JobStatusHandler.java:40)
    at
org.globus.cog.coaster.handlers.RequestHandler.receiveCompleted(RequestHandler.java:88)
    at
org.globus.cog.coaster.channels.AbstractCoasterChannel.handleRequest(AbstractCoasterChannel.java:527)
    at
org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.stepNIO(AbstractStreamCoasterChannel.java:238)
    at
org.globus.cog.coaster.channels.NIOMultiplexer.loop(NIOMultiplexer.java:97)
    at
org.globus.cog.coaster.channels.NIOMultiplexer.run(NIOMultiplexer.java:56)
Caused by: org.globus.cog.abstraction.impl.common.execution.JobException:
    at
    at
    at
    at
    at
    at
Log for this run is:
http://www.mcs.anl.gov/~ketan/absolutepath.log
Thanks for any suggestions on fixing this.
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130826/9cfb2c01/attachment.html>
