[Swift-devel] jobthrottle value does not correspond to number of parallel jobs on local provider
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Tue Oct 23 15:23:16 CDT 2012
I tried CDM DIRECT policy with catsnsleep which gives the following:
CDM[DIRECT]: Linking to /home/train07/ketan_mars/swift/data.txt failed!
the file exists as mentioned in the path above.
When specifying relative path to data.txt, I get /data.txt doesn't exist,
presumably because cdm DIRECT assumes paths to be absolute.
Log attached.
On Tue, Oct 23, 2012 at 4:14 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> > Now trying with cdm. My cdm policy file contains a single line as
> > follows:
> > rule .* DEFAULT /
> Change DEFAULT to DIRECT
> Look at the example at:
> http://www.ci.uchicago.edu/swift/guides/trunk/userguide/userguide.html#_specific_use_cases
> sec 20.5.1 and 20.5.2
> Its best to test this first with simple "catsn-like" examples before you
> try your science app with it, to make sure that the direct processing is
> behaving as you expect.
> - Mike
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20121023/4c6b49fa/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20121023/4c6b49fa/attachment.obj>
