[Swift-devel] jobthrottle value does not correspond to number of parallel jobs on local provider
Michael Wilde wilde at mcs.anl.gov
Tue Oct 23 15:14:41 CDT 2012
> Now trying with cdm. My cdm policy file contains a single line as
> follows:
> rule .* DEFAULT /
Change DEFAULT to DIRECT
Look at the example at:
http://www.ci.uchicago.edu/swift/guides/trunk/userguide/userguide.html#_specific_use_cases
sec 20.5.1 and 20.5.2
Its best to test this first with simple "catsn-like" examples before you try your science app with it, to make sure that the direct processing is behaving as you expect.
- Mike
