[Swift-devel] foreach.max.threads question
David Kelly davidk at ci.uchicago.edu
Tue Oct 16 11:04:43 CDT 2012
Hello,
I have noticed that since the foreach.max.threads changes, the DSSAT script is now running out of memory. I have the heap size set to 4 gigabytes. There are 120K items in gridLists.
The main foreach loop of the script looks like this:
foreach g,i in gridLists {
   file tar_output <single_file_mapper; file=@strcat("output/", gridLists[i], "output.tar.gz")>;
   file part_output <single_file_mapper; file=@strcat("parts/", gridLists[i], ".part")>;
   file in1[] <filesys_mapper; location=@strcat(@arg("scenarios"), "/", gridLists[i]),  pattern="*">; // Scenario files
   file in2[] <filesys_mapper; location=@strcat(@arg("weather"), "/", gridLists[i]), pattern="*">;    // Weather files
   file in3[] <filesys_mapper; location=@arg("refdata"), pattern="*">;				      // Common data
   file in4[] <filesys_mapper; location=@arg("bindata"), pattern="*.EXE">;			      // Binaries
   file in5[] <filesys_mapper; location=@arg("bindata"), pattern="*.pl">;			      // Perl scripts
   file wrapper <single_file_mapper; file="RunDSSAT.sh">;                                             // RunDSSAT wrapper
   (tar_output, part_output) = RunDSSAT(xfile, in1, in2, in3, in4, in5, wrapper);
Is there any way to throttle foreach again, or any other workarounds I could use to avoid this?
David
