[Swift-devel] [swift-support] Channel multiplexer error
Lorenzo Pesce
lpesce at uchicago.edu
Wed Oct 17 09:21:40 CDT 2012
OK, I am trying to rerun the scripts i have using the official version of swift on beagle (that should be trunk)
and put the value of foreach... to 200
Silly problem:
RunID: 20121017-1420-55eqmvlb
Execution failed:
Could not aquire exclusive lock on log file: /lustre/beagle/GCNet/RG/Oreo/o080522_BS1/demo_real-20121004-0239-gcqgkdrf.0.rlog
I had to kill swift with -9 because it did not want to die before.
What is the lock file I need to remove?
On Oct 14, 2012, at 10:48 PM, Mihael Hategan wrote:
> I spoke to Mike on the phone on Friday, and we agreed that
> foreach.max.threads is a bit difficult to use.
> So I removed the throttling for foreach and added it to app invocations.
> It might help with memory consumption if you set it to around the number
> of cpus you have access to.
> I also did some small optimizations to improve memory use. I can run
> about 50K jobs with your script on a 32 bit system with 1GB of heap
> space. I suspect that on 64 bit systems this might require more heap.
> I also added an option to the swift executable to automatically dump a
> copy of the heap when an out of memory condition occurs. Hopefully that
> will help us troubleshoot such problems in the future.
> This is all in trunk.
> Mihael
> On Sat, 2012-10-13 at 04:47 -0500, Kazutaka Takahashi wrote:
>> Hi All,
>> Sorry for a late reply, but I am already at a conference and had not
>> had a chance to try what Mike proposed. I will try later during the
>> second half of the conference, if not after the conference ending next
>> wed.
>> Taka
>> On Thu, Oct 11, 2012 at 7:12 PM, Mihael Hategan <hategan at mcs.anl.gov>
>> wrote:
>> Did you try what Mike proposed?
>> Mihael
>> On Thu, 2012-10-11 at 17:49 -0500, Kazutaka Takahashi wrote:
>>> OK...
>>> The last one died with the same error msg... Please check
>> the both
>>> directories...
>> taka at login4:/lustre/beagle/GCNet/RG/Athena/a080521_BS_new/Cond2>
>> taka at login4:/lustre/beagle/GCNet/RG/Athena/a080521_BS_new/Cond3>
>>> /lustre/beagle/GCNet/bin/Swift/swift: line 164: 8527 Killed
>>> java -Xmx5120M
>> -Djava.endorsed.dirs=/soft/swift/0.93//lib/endorsed
>>> -DUID=3023 -DGLOBUS_HOSTNAME=login4.beagle.ci.uchicago.edu
>>> -DCOG_INSTALL_PATH=/soft/swift/0.93/
>> -Dswift.home=/soft/swift/0.93/
>>> -Duser.home=/lustre/beagle/GCNet
>>> -Djava.security.egd=file:///dev/urandom -XX:+UseParallelGC
>>> -XX:ParallelGCThreads=1
>> -classpath /soft/swift/0.93//etc:/soft/swift/0.93//libexec:/soft/swift/0.93//lib/addressing-1.0.jar:/soft/swift/0.93//lib/ant.jar:/soft/swift/0.93//lib/antlr-2.7.5.jar:/soft/swift/0.93//lib/axis.jar:/soft/swift/0.93//lib/axis-url.jar:/soft/swift/0.93//lib/castor-0.9.6.jar:/soft/swift/0.93//lib/coaster-bootstrap.jar:/soft/swift/0.93//lib/cog-abstraction-common-2.4.jar:/soft/swift/0.93//lib/cog-axis.jar:/soft/swift/0.93//lib/cog-grapheditor-0.47.jar:/soft/swift/0.93//lib/cog-jglobus-1.7.0.jar:/soft/swift/0.93//lib/cog-karajan-0.36-dev.jar:/soft/swift/0.93//lib/cog-provider-clref-gt4_0_0.jar:/soft/swift/0.93//lib/cog-provider-coaster-0.3.jar:/soft/swift/0.93//lib/cog-provider-dcache-0.1.jar:/soft/swift/0.93//lib/cog-provider-gt2-2.4.jar:/soft/swift/0.93//lib/cog-provider-gt4_0_0-2.5.jar:/soft/swift/0.93//lib/cog-provider-local-2.2.jar:/soft/swift/0.93//lib/cog-provider-localscheduler-0.4.jar:/soft/swift/0.93//lib/cog-provider-ssh-2.4.jar:/soft/swift/0.93//lib/cog-provider-webdav-2.1.jar:/soft/swift/0.93//lib/cog-resources-1.0.jar:/soft/swift/0.93//lib/cog-swift-svn.jar:/soft/swift/0.93//lib/cog-trap-1.0.jar:/soft/swift/0.93//lib/cog-url.jar:/soft/swift/0.93//lib/cog-util-0.92.jar:/soft/swift/0.93//lib/commonj.jar:/soft/swift/0.93//lib/commons-beanutils.jar:/soft/swift/0.93//lib/commons-collections-3.0.jar:/soft/swift/0.93//lib/commons-digester.jar:/soft/swift/0.93//lib/commons-discovery.jar:/soft/swift/0.93//lib/commons-httpclient.jar:/soft/swift/0.93//lib/commons-logging-1.1.jar:/soft/swift/0.93//lib/concurrent.jar:/soft/swift/0.93//lib/cryptix32.jar:/soft/swift/0.93//lib/cryptix-asn1.jar:/soft/swift/0.93//lib/cryptix.jar:/soft/swift/0.93//lib/globus_delegation_service.jar:/soft/swift/0.93//lib/globus_delegation_stubs.jar:/soft/swift/0.93//lib/globus_wsrf_mds_aggregator_stubs.jar:/soft/swift/0.93//lib/globus_wsrf_rendezvous_service.jar:/soft/swift/0.93//lib/globus_wsrf_rendezvous_stubs.jar:/soft/swift/0.93//lib/globus_wsrf_rft_stubs.jar:/soft/swift/0.93//lib/gram-client.jar:/soft/swift/0.93//lib/gram-stubs.jar:/soft/swift/0.93//lib/gram-utils.jar:/soft/swift/0.93//lib/j2ssh-common-0.2.2.jar:/soft/swift/0.93//lib/j2ssh-core-0.2.2-patch-b.jar:/soft/swift/0.93//lib/jakarta-regexp-1.2.jar:/soft/swift/0.93//lib/jakarta-slide-webdavlib-2.0.jar:/soft/swift/0.93//lib/jaxrpc.jar:/soft/swift/0.93//lib/jce-jdk13-131.jar:/soft/swift/0.93//lib/jgss.jar:/soft/swift/0.93//lib/jline-0.9.94.jar:/soft/swift/0.93//lib/jsr173_1.0_api.jar:/soft/swift/0.93//lib/jug-lgpl-2.0.0.jar:/soft/swift/0.93//lib/junit.jar:/soft/swift/0.93//lib/log4j-1.2.16.jar:/soft/swift/0.93//lib/naming-common.jar:/soft/swift/0.93//lib/naming-factory.jar:/soft/swift/0.93//lib/naming-java.jar:/soft/swift/0.93//lib/naming-resources.jar:/soft/swift/0.93//lib/opensaml.jar:/soft/swift/0.93//lib/puretls.jar:/soft/swift/0.93//lib/resolver.jar:/soft/swift/0.93//lib/saaj.jar:/soft/swift/0.93//lib/stringtemplate.jar:/soft/swift/0.93//lib/vdldefinitions.jar:/soft/swift/0.93//lib/wsdl4j.jar:/soft/swift/0.93//lib/wsrf_core.jar:/soft/swift/0.93//lib/wsrf_core_stubs.jar:/soft/swift/0.93//lib/wsrf_mds_index_stubs.jar:/soft/swift/0.93//lib/wsrf_mds_usefulrp_schema_stubs.jar:/soft/swift/0.93//lib/wsrf_provider_jce.jar:/soft/swift/0.93//lib/wsrf_tools.jar:/soft/swift/0.93//lib/wss4j.jar:/soft/swift/0.93//lib/xalan.jar:/soft/swift/0.93//lib/xbean.jar:/soft/swift/0.93//lib/xbean_xpath.jar:/soft/swift/0.93//lib/xercesImpl.jar:/soft/swift/0.93//lib/xml-apis.jar:/soft/swift/0.93//lib/xmlsec.jar:/soft/swift/0.93//lib/xpp3-1.1.3.4d_b4_min.jar:/soft/swift/0.93//lib/xstream-1.1.1-patched.jar: org.griphyn.vdl.karajan.Loader '-config' 'demo_realcf.cf' '-sites.file' 'demo_realSites.xml' '-tc.file' 'demo_realtc.tc' 'demo_real.swift'
>> What is essential is invisible to the eye
