[Swift-devel] foreach.max.threads question
Mihael Hategan hategan at mcs.anl.gov
Tue Oct 16 13:44:47 CDT 2012
What was foreach.max.threads set to before?
On Tue, 2012-10-16 at 11:04 -0500, David Kelly wrote:
> Hello,
> I have noticed that since the foreach.max.threads changes, the DSSAT script is now running out of memory. I have the heap size set to 4 gigabytes. There are 120K items in gridLists.
> The main foreach loop of the script looks like this:
> foreach g,i in gridLists {
>    file tar_output <single_file_mapper; file=@strcat("output/", gridLists[i], "output.tar.gz")>;
>    file part_output <single_file_mapper; file=@strcat("parts/", gridLists[i], ".part")>;
>    file in1[] <filesys_mapper; location=@strcat(@arg("scenarios"), "/", gridLists[i]),  pattern="*">; // Scenario files
>    file in2[] <filesys_mapper; location=@strcat(@arg("weather"), "/", gridLists[i]), pattern="*">;    // Weather files
>    file in3[] <filesys_mapper; location=@arg("refdata"), pattern="*">;				      // Common data
>    file in4[] <filesys_mapper; location=@arg("bindata"), pattern="*.EXE">;			      // Binaries
>    file in5[] <filesys_mapper; location=@arg("bindata"), pattern="*.pl">;			      // Perl scripts
>    file wrapper <single_file_mapper; file="RunDSSAT.sh">;                                             // RunDSSAT wrapper
>    (tar_output, part_output) = RunDSSAT(xfile, in1, in2, in3, in4, in5, wrapper);
> Is there any way to throttle foreach again, or any other workarounds I could use to avoid this?
> Thanks,
> David
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
