[Swift-devel] Issues with Montage & Swift-CDM
    Jonathan Monette
    jonmon at mcs.anl.gov
    Thu Mar 22 15:44:50 CDT 2012
Was that with CDM in your run?  I am going to take a look too as to why that is showing up.
On Mar 22, 2012, at 3:42 PM, Justin M Wozniak wrote:
> Ok, I can get it started but I get:
> 2012-03-22 20:24:06,048+0000 INFO  SetFieldValue Set: projected_images[0]=null
> 2012-03-22 20:24:06,049+0000 INFO  SetFieldValue Set: projected_images[6]=null
> 2012-03-22 20:24:06,050+0000 INFO  SetFieldValue Set: projected_images[7]=null
> resulting in:
> File not found: /gpfs/home/wozniak/SwiftMontage/scripts/./proj_dir/null
> This looks like a Swift bug.  However, do you guys have an existing workaround?
> 	Thanks
> On Thu, 22 Mar 2012, Emalayan Vairavanathan wrote:
>> Hi Justin,
>> Please use ./run_local.sh to run the montage without cdm locally on the headnode.
>> The rest of the scripts (run-workers.sh, run.sh, run-swift.sh, main.sh) are written to run experiments in our cluster and wont work in Surveyor.
>> Please let me know if you have questions.
>> Thank you
>> Emalayan
>> ________________________________
>> From: Justin M Wozniak <wozniak at mcs.anl.gov>
>> To: Emalayan Vairavanathan <svemalayan at yahoo.com> Cc: "swift-devel at ci.uchicago.edu" <swift-devel at ci.uchicago.edu>; MosaStore <mosastore at googlegroups.com>; matei <matei at ece.ubc.ca> Sent: Thursday, 22 March 2012 11:54 AM
>> Subject: Re: [Swift-devel] Issues with Montage & Swift-CDM
>> On Wed, 21 Mar 2012, Emalayan Vairavanathan wrote:
>>>     But I just setup everything on Surveyor and it works locally on the head node. You can find the setup here.
>>>   /home/emalayan/app/montage-swift-cdm/SwiftMontage/scripts
>> What is the entry point?
>> Are we missing common.sh?
>> -- Justin M Wozniak
> Justin M Wozniak_______________________________________________
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
