[Swift-devel] Issues with Montage & Swift-CDM
Justin M Wozniak wozniak at mcs.anl.gov
Thu Mar 22 15:42:40 CDT 2012
Ok, I can get it started but I get:
2012-03-22 20:24:06,048+0000 INFO  SetFieldValue Set:
projected_images[0]=null
2012-03-22 20:24:06,049+0000 INFO  SetFieldValue Set:
projected_images[6]=null
2012-03-22 20:24:06,050+0000 INFO  SetFieldValue Set:
projected_images[7]=null
resulting in:
File not found: /gpfs/home/wozniak/SwiftMontage/scripts/./proj_dir/null
This looks like a Swift bug.  However, do you guys have an existing
workaround?
 	Thanks
On Thu, 22 Mar 2012, Emalayan Vairavanathan wrote:
> Hi Justin,
> Please use ./run_local.sh to run the montage without cdm locally on the headnode.
> The rest of the scripts (run-workers.sh, run.sh, run-swift.sh, main.sh) are written to run experiments in our cluster and wont work in Surveyor.
> Please let me know if you have questions.
> Thank you
> Emalayan
> ________________________________
> From: Justin M Wozniak <wozniak at mcs.anl.gov>
> To: Emalayan Vairavanathan <svemalayan at yahoo.com>
> Cc: "swift-devel at ci.uchicago.edu" <swift-devel at ci.uchicago.edu>; MosaStore <mosastore at googlegroups.com>; matei <matei at ece.ubc.ca>
> Sent: Thursday, 22 March 2012 11:54 AM
> Subject: Re: [Swift-devel] Issues with Montage & Swift-CDM
> On Wed, 21 Mar 2012, Emalayan Vairavanathan wrote:
>>     But I just setup everything on Surveyor and it works locally on the head node. You can find the setup here.
>>   /home/emalayan/app/montage-swift-cdm/SwiftMontage/scripts
> What is the entry point?
> Are we missing common.sh?
> -- Justin M Wozniak
Justin M Wozniak
