[Swift-devel] Issues with Montage & Swift-CDM
Justin M Wozniak
wozniak at mcs.anl.gov
Thu Mar 22 15:49:24 CDT 2012
This run had no CDM file.
On Thu, 22 Mar 2012, Jonathan Monette wrote:
> Was that with CDM in your run? I am going to take a look too as to why that is showing up.
> On Mar 22, 2012, at 3:42 PM, Justin M Wozniak wrote:
>> Ok, I can get it started but I get:
>> 2012-03-22 20:24:06,048+0000 INFO SetFieldValue Set: projected_images[0]=null
>> 2012-03-22 20:24:06,049+0000 INFO SetFieldValue Set: projected_images[6]=null
>> 2012-03-22 20:24:06,050+0000 INFO SetFieldValue Set: projected_images[7]=null
>> resulting in:
>> File not found: /gpfs/home/wozniak/SwiftMontage/scripts/./proj_dir/null
>> This looks like a Swift bug. However, do you guys have an existing workaround?
>> Thanks
>> On Thu, 22 Mar 2012, Emalayan Vairavanathan wrote:
>>> Hi Justin,
>>> Please use ./run_local.sh to run the montage without cdm locally on the headnode.
>>> The rest of the scripts (run-workers.sh, run.sh, run-swift.sh, main.sh) are written to run experiments in our cluster and wont work in Surveyor.
>>> Please let me know if you have questions.
>>> Thank you
>>> Emalayan
>>> ________________________________
>>> From: Justin M Wozniak <wozniak at mcs.anl.gov>
>>> To: Emalayan Vairavanathan <svemalayan at yahoo.com> Cc: "swift-devel at ci.uchicago.edu" <swift-devel at ci.uchicago.edu>; MosaStore <mosastore at googlegroups.com>; matei <matei at ece.ubc.ca> Sent: Thursday, 22 March 2012 11:54 AM
>>> Subject: Re: [Swift-devel] Issues with Montage & Swift-CDM
>>> On Wed, 21 Mar 2012, Emalayan Vairavanathan wrote:
>>>> But I just setup everything on Surveyor and it works locally on the head node. You can find the setup here.
>>>> /home/emalayan/app/montage-swift-cdm/SwiftMontage/scripts
>>> What is the entry point?
>>> Are we missing common.sh?
>>> -- Justin M Wozniak
>> Justin M Wozniak_______________________________________________
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Justin M Wozniak
