[Swift-devel] Mosaswift update
    Justin M Wozniak
    wozniak at mcs.anl.gov
    Wed Mar 14 15:02:28 CDT 2012
Ok, then it's a typo on readlinE .
On Wed, 14 Mar 2012, Jonathan Monette wrote:
> I am not sure.  I thought readlink returned the absolute path of the
> link which is what I wanted to use.  I am not sure how readlink behaves
> on the compute nodes.  This was my first attempt at getting around the
> link but I do not think this is working.
>>> I say semi working because I intended the script to build up output during the stages on the swift run and the final output would show that it was stored temporarily in /tmp.  This is not happening as the final output for the file contains only the last line(a Hello from <id> line). I believe this is due to how CDM using symlinks for the files that is matched, so a symlink is being overwritten instead of at the file it points to.  I ran into this problem in the past(but this is documented in the user guide) and just need verify that this is indeed the issue.
>> In the past, the application unlinked the link.  It looks like you are appending to the link.
>> infile=`readlink $1`
>> outfile=`readline $2`
>> cat $infile >> $outfile
>> Is there a case in which the readlink affects the behavior of this sequence?
>> Does readline work correctly on the BG/P compute node?
>> 	Justin
>> Justin M Wozniak
Justin M Wozniak
