[Swift-devel] Mosaswift update
Jonathan Monette
jonmon at mcs.anl.gov
Wed Mar 14 15:05:47 CDT 2012
Oh, thanks, didn't catch that. Trying another run right now but I think someone is using all of surveyor right now, but manual coaster service job is stuck in the queue state.
On Mar 14, 2012, at 3:02 PM, Justin M Wozniak wrote:
> Ok, then it's a typo on readlinE .
> On Wed, 14 Mar 2012, Jonathan Monette wrote:
>> I am not sure. I thought readlink returned the absolute path of the link which is what I wanted to use. I am not sure how readlink behaves on the compute nodes. This was my first attempt at getting around the link but I do not think this is working.
>>>> I say semi working because I intended the script to build up output during the stages on the swift run and the final output would show that it was stored temporarily in /tmp. This is not happening as the final output for the file contains only the last line(a Hello from <id> line). I believe this is due to how CDM using symlinks for the files that is matched, so a symlink is being overwritten instead of at the file it points to. I ran into this problem in the past(but this is documented in the user guide) and just need verify that this is indeed the issue.
>>> In the past, the application unlinked the link. It looks like you are appending to the link.
>>> infile=`readlink $1`
>>> outfile=`readline $2`
>>> cat $infile >> $outfile
>>> Is there a case in which the readlink affects the behavior of this sequence?
>>> Does readline work correctly on the BG/P compute node?
>>> Justin
>>> Justin M Wozniak
> Justin M Wozniak
