[Swift-devel] Mosaswift update
Jonathan Monette jonmon at mcs.anl.gov
Wed Mar 14 14:45:54 CDT 2012
I am not sure.  I thought readlink returned the absolute path of the link which is what I wanted to use.  I am not sure how readlink behaves on the compute nodes.  This was my first attempt at getting around the link but I do not think this is working.
On Mar 14, 2012, at 2:43 PM, Justin M Wozniak wrote:
> On Wed, 14 Mar 2012, Jonathan Monette wrote:
>> I say semi working because I intended the script to build up output during the stages on the swift run and the final output would show that it was stored temporarily in /tmp.  This is not happening as the final output for the file contains only the last line(a Hello from <id> line). I believe this is due to how CDM using symlinks for the files that is matched, so a symlink is being overwritten instead of at the file it points to.  I ran into this problem in the past(but this is documented in the user guide) and just need verify that this is indeed the issue.
> In the past, the application unlinked the link.  It looks like you are appending to the link.
> infile=`readlink $1`
> outfile=`readline $2`
> cat $infile >> $outfile
> Is there a case in which the readlink affects the behavior of this sequence?
> Does readline work correctly on the BG/P compute node?
> 	Justin
> Justin M Wozniak
