[Swift-devel] Torus rank
Zhao Zhang zhaozhang at uchicago.edu
Tue Mar 6 14:41:45 CST 2012
Hi, Emalayan
Emalayan Vairavanathan wrote:
> Hi Kaz,
> I found the following about tours rank from
> http://wiki.mcs.anl.gov/zeptoos/index.php/FAQ and want to double check
> with you still this information valid.
>       Torus rank:-
>       A torus rank is a number identifying a compute node within a
>       whole partition. In a way, it is much "nicer" than a pset rank
>       since it is unique within a job and it also starts from 0.
> - A shell script can easily calculate it from other fields:
> TORUS_RANK=`echo $BG_PSETORG | awk "{print \\$1 + \\$2 * $BG_XSIZE + \
>             \\$3 * $BG_XSIZE * $BG_YSIZE}"
> It would be great if you can make sure that the tours rank is unique
> within a partition and always starts from zero regardless of the
> following.
>  - Partition size (fraction of pset / multiple of psets / both )
>  - Platform (Surveyor / Intrepid)
>  - Kernel profiles.
yes, this is true regardless of partition size, platform, and ZeptoOS
kernel profiles(zeptoos, zepto-vn-eval, and the one you use for mosa).
best
zhao
> (Note: I am asking this in order to figure out a easy way to deploy
> MosaStore at BG/P at large scale. I did few tests with different
> partition size in Surveyor and it seems the tours rank is unique and
> always starts from zero.)
> Thank you
> Emalayan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
