[Swift-devel] Torus rank
Emalayan Vairavanathan svemalayan at yahoo.com
Tue Mar 6 15:22:20 CST 2012
Great. Thank you Zhao.
To: Emalayan Vairavanathan <svemalayan at yahoo.com>
Cc: Kazutomo Yoshii <kazutomo at mcs.anl.gov>; "swift-devel at ci.uchicago.edu" <swift-devel at ci.uchicago.edu>; MosaStore <mosastore at googlegroups.com>
Sent: Tuesday, 6 March 2012 12:41 PM
Subject: Re: [Swift-devel] Torus rank
Hi, Emalayan
Emalayan Vairavanathan wrote:
> Hi Kaz,
> I found the following about tours rank from
> http://wiki.mcs.anl.gov/zeptoos/index.php/FAQ and want to double check
> with you still this information valid.
>       Torus rank:-
>       A torus rank is a number identifying a compute node within a
>       whole partition. In a way, it is much "nicer" than a pset rank
>       since it is unique within a job and it also starts from 0.
> - A shell script can easily calculate it from other fields:
> TORUS_RANK=`echo $BG_PSETORG | awk "{print \\$1 + \\$2 * $BG_XSIZE + \
>             \\$3 * $BG_XSIZE * $BG_YSIZE}"
> It would be great if you can make sure that the tours rank is unique
> within a partition and always starts from zero regardless of the
> following.
>  - Partition size (fraction of pset / multiple of psets / both )
>  - Platform (Surveyor / Intrepid)
>  - Kernel profiles.
yes, this is true regardless of partition size, platform, and ZeptoOS
kernel profiles(zeptoos, zepto-vn-eval, and the one you use for mosa).
best
zhao
> (Note: I am asking this in order to figure out a easy way to deploy
> MosaStore at BG/P at large scale. I did few tests with different
> partition size in Surveyor and it seems the tours rank is unique and
> always starts from zero.)
> Thank you
> Emalayan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
You received this message because you are subscribed to the Google Groups "MosaStore" group.
To post to this group, send email to mosastore at googlegroups.com.
To unsubscribe from this group, send email to mosastore+unsubscribe at googlegroups.com.
For more options, visit this group at http://groups.google.com/group/mosastore?hl=en.
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20120306/56f0f619/attachment.html>
