[Swift-devel] Urgent Friday evening problem ;	-) :: vanilla R on Beagle
    Lorenzo Pesce
    lpesce at uchicago.edu
    Mon Jul 30 13:27:06 CDT 2012
The good news is that for python worked as you said for the version they provide us with.
We could both run multiple instances at the same time, but the environmental variables were not corrupted anymore.
Next step we'll test building a version and see if it does what we want.
R-2.15.1 instead of building brings down the login nodes. Literally. This morning I tried to build R-2.15.1  and
while running ./configure the login poofed.
Correlation is not causality, but I killed another node trying again, so I am pretty sure it is.
This is the last line before evaporating:
checking whether integer division by zero raises SIGFPE...
under investigation.
temporary directory was set to /lustre/beagle/`whoami`'''' , but it doesn't seem to matter whether it is /tmp or lustre
On Jul 27, 2012, at 5:11 PM, Michael Wilde wrote:
> Lorenzo, I think the R in /home/wilde/R/beagle/R-2.13.1 ws indeed built with module gcc, and thus should run with "node packing" (ie multiple parallel copies per node).
> Build notes are in /home/wilde/R/README
> The build script used was: /home/wilde/R/releases/build.beagle
> which does:
> mod unload $(mod list | grep -i prg)
> mod load gcc
> echo Using compiler: $(mod list | grep gcc)
> echo 'Checking that PrgEnv has been unloaded (should be blank!):' $(mod list | grep -i prg)
> rm -rf $MYRBUILD/beagle/$REL
> #mkdir -p $MYRBUILD/beagle/$REL
> cd $MYRBUILD/beagle
> tar zxf $MYRBUILD/$REL.tar.gz
> cd $REL
> # make clean
> ./configure --prefix=$MYRINSTALL/beagle/$REL # --enable-R-shlib
> make
> make install
> - Mike
>> From: "Michael Wilde" <wilde at mcs.anl.gov>
>> To: "Lorenzo Pesce" <lpesce at uchicago.edu>
>> Cc: "swift-devel Devel" <swift-devel at ci.uchicago.edu>
>> Sent: Friday, July 27, 2012 5:02:31 PM
>> Subject: Re: [Swift-devel] Urgent Friday evening problem ; -) :: vanilla R on Beagle
>> Hi Lorenzo, sorry, just saw your message. Try this R:
>> login1$ pwd
>> login1$ ls
>> COPYING INSTALL Makefile.fw NEWS ONEWS README VERSION config.site
>> configure.ac etc/ m4/ share/ tests/
>> ChangeLog Makeconf.in Makefile.in NEWS.pdf OONEWS SVN-REVISION bin/
>> configure* doc/ lib64/ po/ src/ tools/
>> login1$ bin/R
>> R version 2.13.1 (2011-07-08)
>> Copyright (C) 2011 The R Foundation for Statistical Computing
>> - Mike
>>> From: "Lorenzo Pesce" <lpesce at uchicago.edu>
>>> To: "Michael Wilde" <wilde at mcs.anl.gov>
>>> Sent: Friday, July 27, 2012 2:24:38 PM
>>> Subject: Urgent Friday evening problem ;-) :: vanilla R on Beagle
>>> Has any one a version of R that works on the compute nodes and can
>>> be
>>> packed?
>>> If not, I will build one.
>>> I just convinced a user of beagle to move all her urgent analysis to
>>> swift. Please :-)
>>> Lorenzo
>> Michael Wilde
>> Computation Institute, University of Chicago
>> Mathematics and Computer Science Division
>> Argonne National Laboratory
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Michael Wilde
