[Swift-devel] merge 0.93 -> trunk
Mihael Hategan hategan at mcs.anl.gov
Sun Jan 29 18:15:44 CST 2012
Maybe the checkout happened in the middle of a commit?
Is anybody seeing this with a clean checkout?
On Sun, 2012-01-29 at 16:07 -0600, David Kelly wrote:
> It looks like the compile failed and the test did not run last night. Here is the error I am getting:
>     [javac] /swift/swift-trunk/cog/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/LocalTCPService.java:29: org.globus.cog.abstraction.coaster.service.LocalTCPService is not abstract and does not override abstract method registrationReceived(java.lang.String,java.lang.String,org.globus.cog.karajan.workflow.service.channels.KarajanChannel,java.util.Map<java.lang.String,java.lang.String>) in org.globus.cog.abstraction.coaster.service.Registering
>     [javac] public class LocalTCPService extends GSSService implements Registering {
>     [javac]        ^
>     [javac] /swift/swift-trunk/cog/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/LocalTCPService.java:64: registrationReceived(java.lang.String,java.lang.String,java.lang.String,org.globus.cog.karajan.workflow.service.channels.ChannelContext,java.util.Map<java.lang.String,java.lang.String>) in org.globus.cog.abstraction.coaster.service.RegistrationManager cannot be applied to (java.lang.String,java.lang.String,java.lang.String,org.globus.cog.karajan.workflow.service.channels.ChannelContext)
>     [javac]         registrationManager.registrationReceived(blockid, wid, url, cc);
>     [javac]                            ^
>     [javac] Note: /swift/swift-trunk/cog/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Block.java uses or overrides a deprecated API.
>     [javac] Note: Recompile with -Xlint:deprecation for details.
>     [javac] Note: /swift/swift-trunk/cog/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/BQPStatusHandler.java uses unchecked or unsafe operations.
>     [javac] Note: Recompile with -Xlint:unchecked for details.
>     [javac] 2 errors
> BUILD FAILED
> /swift/swift-trunk/cog/modules/swift/build.xml:73: The following error occurred while executing this line:
> /swift/swift-trunk/cog/mbuild.xml:445: The following error occurred while executing this line:
> /swift/swift-trunk/cog/mbuild.xml:79: The following error occurred while executing this line:
> /swift/swift-trunk/cog/mbuild.xml:52: The following error occurred while executing this line:
> /swift/swift-trunk/cog/modules/swift/dependencies.xml:13: The following error occurred while executing this line:
> /swift/swift-trunk/cog/mbuild.xml:163: The following error occurred while executing this line:
> /swift/swift-trunk/cog/mbuild.xml:168: The following error occurred while executing this line:
> /swift/swift-trunk/cog/modules/provider-coaster/build.xml:59: The following error occurred while executing this line:
> /swift/swift-trunk/cog/mbuild.xml:466: The following error occurred while executing this line:
> /swift/swift-trunk/cog/mbuild.xml:229: Compile failed; see the compiler error output for details.
> > From: "Michael Wilde" <wilde at mcs.anl.gov>
> > To: "Mihael Hategan" <hategan at mcs.anl.gov>
> > Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>
> > Sent: Sunday, January 29, 2012 10:27:18 AM
> > Subject: Re: [Swift-devel] merge 0.93 -> trunk
> > Excellent - thanks! David, can you tell us how the nightly tests in
> > trunk were affected by the integration?
> > - Mike
> > > From: "Mihael Hategan" <hategan at mcs.anl.gov>
> > > To: "Swift Devel" <swift-devel at ci.uchicago.edu>
> > > Sent: Saturday, January 28, 2012 11:01:54 PM
> > > Subject: [Swift-devel] merge 0.93 -> trunk
> > > Did the merge. I still need to do some sanity checks, so it may be
> > > shaky
> > > at the moment.
> > > Mihael
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> > Michael Wilde
> > Computation Institute, University of Chicago
> > Mathematics and Computer Science Division
> > Argonne National Laboratory
