[Swift-devel] merge 0.93 -> trunk
Jonathan Monette jonmon at mcs.anl.gov
Mon Jan 30 08:45:06 CST 2012
I am seeing the same error when trying to compile trunk.
On Jan 29, 2012, at 6:15 PM, Mihael Hategan wrote:
> Maybe the checkout happened in the middle of a commit?
> Is anybody seeing this with a clean checkout?
> On Sun, 2012-01-29 at 16:07 -0600, David Kelly wrote:
>> It looks like the compile failed and the test did not run last night. Here is the error I am getting:
>>    [javac] /swift/swift-trunk/cog/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/LocalTCPService.java:29: org.globus.cog.abstraction.coaster.service.LocalTCPService is not abstract and does not override abstract method registrationReceived(java.lang.String,java.lang.String,org.globus.cog.karajan.workflow.service.channels.KarajanChannel,java.util.Map<java.lang.String,java.lang.String>) in org.globus.cog.abstraction.coaster.service.Registering
>>    [javac] public class LocalTCPService extends GSSService implements Registering {
>>    [javac]        ^
>>    [javac] /swift/swift-trunk/cog/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/LocalTCPService.java:64: registrationReceived(java.lang.String,java.lang.String,java.lang.String,org.globus.cog.karajan.workflow.service.channels.ChannelContext,java.util.Map<java.lang.String,java.lang.String>) in org.globus.cog.abstraction.coaster.service.RegistrationManager cannot be applied to (java.lang.String,java.lang.String,java.lang.String,org.globus.cog.karajan.workflow.service.channels.ChannelContext)
>>    [javac]         registrationManager.registrationReceived(blockid, wid, url, cc);
>>    [javac]                            ^
>>    [javac] Note: /swift/swift-trunk/cog/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Block.java uses or overrides a deprecated API.
>>    [javac] Note: Recompile with -Xlint:deprecation for details.
>>    [javac] Note: /swift/swift-trunk/cog/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/BQPStatusHandler.java uses unchecked or unsafe operations.
>>    [javac] Note: Recompile with -Xlint:unchecked for details.
>>    [javac] 2 errors
>> BUILD FAILED
>> /swift/swift-trunk/cog/modules/swift/build.xml:73: The following error occurred while executing this line:
>> /swift/swift-trunk/cog/mbuild.xml:445: The following error occurred while executing this line:
>> /swift/swift-trunk/cog/mbuild.xml:79: The following error occurred while executing this line:
>> /swift/swift-trunk/cog/mbuild.xml:52: The following error occurred while executing this line:
>> /swift/swift-trunk/cog/modules/swift/dependencies.xml:13: The following error occurred while executing this line:
>> /swift/swift-trunk/cog/mbuild.xml:163: The following error occurred while executing this line:
>> /swift/swift-trunk/cog/mbuild.xml:168: The following error occurred while executing this line:
>> /swift/swift-trunk/cog/modules/provider-coaster/build.xml:59: The following error occurred while executing this line:
>> /swift/swift-trunk/cog/mbuild.xml:466: The following error occurred while executing this line:
>> /swift/swift-trunk/cog/mbuild.xml:229: Compile failed; see the compiler error output for details.
>> ----- Original Message -----
>>> From: "Michael Wilde" <wilde at mcs.anl.gov>
>>> To: "Mihael Hategan" <hategan at mcs.anl.gov>
>>> Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>
>>> Sent: Sunday, January 29, 2012 10:27:18 AM
>>> Subject: Re: [Swift-devel] merge 0.93 -> trunk
>>> Excellent - thanks! David, can you tell us how the nightly tests in
>>> trunk were affected by the integration?
>>> - Mike
>>>> From: "Mihael Hategan" <hategan at mcs.anl.gov>
>>>> To: "Swift Devel" <swift-devel at ci.uchicago.edu>
>>>> Sent: Saturday, January 28, 2012 11:01:54 PM
>>>> Subject: [Swift-devel] merge 0.93 -> trunk
>>>> Did the merge. I still need to do some sanity checks, so it may be
>>>> shaky
>>>> at the moment.
>>>> Mihael
>>>> _______________________________________________
>>>> Swift-devel mailing list
>>>> Swift-devel at ci.uchicago.edu
>>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
>>> Michael Wilde
>>> Computation Institute, University of Chicago
>>> Mathematics and Computer Science Division
>>> Argonne National Laboratory
