[Swift-devel] merge 0.93 -> trunk
David Kelly davidk at ci.uchicago.edu
Sun Jan 29 16:07:14 CST 2012
It looks like the compile failed and the test did not run last night. Here is the error I am getting:
    [javac] /swift/swift-trunk/cog/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/LocalTCPService.java:29: org.globus.cog.abstraction.coaster.service.LocalTCPService is not abstract and does not override abstract method registrationReceived(java.lang.String,java.lang.String,org.globus.cog.karajan.workflow.service.channels.KarajanChannel,java.util.Map<java.lang.String,java.lang.String>) in org.globus.cog.abstraction.coaster.service.Registering
    [javac] public class LocalTCPService extends GSSService implements Registering {
    [javac]        ^
    [javac] /swift/swift-trunk/cog/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/LocalTCPService.java:64: registrationReceived(java.lang.String,java.lang.String,java.lang.String,org.globus.cog.karajan.workflow.service.channels.ChannelContext,java.util.Map<java.lang.String,java.lang.String>) in org.globus.cog.abstraction.coaster.service.RegistrationManager cannot be applied to (java.lang.String,java.lang.String,java.lang.String,org.globus.cog.karajan.workflow.service.channels.ChannelContext)
    [javac]         registrationManager.registrationReceived(blockid, wid, url, cc);
    [javac]                            ^
    [javac] Note: /swift/swift-trunk/cog/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Block.java uses or overrides a deprecated API.
    [javac] Note: Recompile with -Xlint:deprecation for details.
    [javac] Note: /swift/swift-trunk/cog/modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/BQPStatusHandler.java uses unchecked or unsafe operations.
    [javac] Note: Recompile with -Xlint:unchecked for details.
    [javac] 2 errors
BUILD FAILED
/swift/swift-trunk/cog/modules/swift/build.xml:73: The following error occurred while executing this line:
/swift/swift-trunk/cog/mbuild.xml:445: The following error occurred while executing this line:
/swift/swift-trunk/cog/mbuild.xml:79: The following error occurred while executing this line:
/swift/swift-trunk/cog/mbuild.xml:52: The following error occurred while executing this line:
/swift/swift-trunk/cog/modules/swift/dependencies.xml:13: The following error occurred while executing this line:
/swift/swift-trunk/cog/mbuild.xml:163: The following error occurred while executing this line:
/swift/swift-trunk/cog/mbuild.xml:168: The following error occurred while executing this line:
/swift/swift-trunk/cog/modules/provider-coaster/build.xml:59: The following error occurred while executing this line:
/swift/swift-trunk/cog/mbuild.xml:466: The following error occurred while executing this line:
/swift/swift-trunk/cog/mbuild.xml:229: Compile failed; see the compiler error output for details.
----- Original Message -----
> From: "Michael Wilde" <wilde at mcs.anl.gov>
> To: "Mihael Hategan" <hategan at mcs.anl.gov>
> Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Sunday, January 29, 2012 10:27:18 AM
> Subject: Re: [Swift-devel] merge 0.93 -> trunk
> Excellent - thanks! David, can you tell us how the nightly tests in
> trunk were affected by the integration?
> - Mike
> > From: "Mihael Hategan" <hategan at mcs.anl.gov>
> > To: "Swift Devel" <swift-devel at ci.uchicago.edu>
> > Sent: Saturday, January 28, 2012 11:01:54 PM
> > Subject: [Swift-devel] merge 0.93 -> trunk
> > Did the merge. I still need to do some sanity checks, so it may be
> > shaky
> > at the moment.
> > Mihael
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
