[Swift-devel] command line ssh provider...
Jonathan Monette jonmon at mcs.anl.gov
Mon Jan 16 15:24:27 CST 2012
So. I started a Swift run and when it was waiting for me to type in a password I opened another terminal and kill what looked like the process that was connecting to bridled.  Swift just started a new process.  I then kill -9 the process and this time Swift crashed.  Still no ssh debug messages appear in the logs.
On Jan 16, 2012, at 1:16 PM, Mihael Hategan wrote:
> On Mon, 2012-01-16 at 11:14 -0800, Mihael Hategan wrote:
>> On Mon, 2012-01-16 at 13:10 -0600, Jonathan Monette wrote:
>>> as the first parameter in the ArrayList.  However I cannot make
>>> anything show up in the logs.  I tried entering in the wrong password
>>> as well as the correct password.  Is there anything else that needs to
>>> be added to the JobSubmissionTaskHandler file?  Or where else should I
>>> look besides the logs?
>> You need to type some wrong password to make the job fail which captures
>> the output.
> But then that won't work without a GUI askpass so, nevermind. You can
> try to kill the ssh sub-process?
