[Swift-devel] command line ssh provider...
Mihael Hategan hategan at mcs.anl.gov
Mon Jan 16 13:16:31 CST 2012
On Mon, 2012-01-16 at 11:14 -0800, Mihael Hategan wrote:
> On Mon, 2012-01-16 at 13:10 -0600, Jonathan Monette wrote:
> > as the first parameter in the ArrayList.  However I cannot make
> > anything show up in the logs.  I tried entering in the wrong password
> > as well as the correct password.  Is there anything else that needs to
> > be added to the JobSubmissionTaskHandler file?  Or where else should I
> > look besides the logs?
> You need to type some wrong password to make the job fail which captures
> the output.
But then that won't work without a GUI askpass so, nevermind. You can
try to kill the ssh sub-process?
