[Swift-devel] command line ssh provider...
Mihael Hategan hategan at mcs.anl.gov
Mon Jan 16 21:29:02 CST 2012
Hmm.
I added logging of stdout/stderr in the local provider when the job
fails. You may need to enable DEBUG in log4j.properties on
org.globus.cog.abstraction.impl.execution.local.JobSubmissionTaskHandler.
Mihael
On Mon, 2012-01-16 at 15:24 -0600, Jonathan Monette wrote:
> So. I started a Swift run and when it was waiting for me to type in a password I opened another terminal and kill what looked like the process that was connecting to bridled.  Swift just started a new process.  I then kill -9 the process and this time Swift crashed.  Still no ssh debug messages appear in the logs.
> On Jan 16, 2012, at 1:16 PM, Mihael Hategan wrote:
> > On Mon, 2012-01-16 at 11:14 -0800, Mihael Hategan wrote:
> >> On Mon, 2012-01-16 at 13:10 -0600, Jonathan Monette wrote:
> >>> as the first parameter in the ArrayList.  However I cannot make
> >>> anything show up in the logs.  I tried entering in the wrong password
> >>> as well as the correct password.  Is there anything else that needs to
> >>> be added to the JobSubmissionTaskHandler file?  Or where else should I
> >>> look besides the logs?
> >> You need to type some wrong password to make the job fail which captures
> >> the output.
> > But then that won't work without a GUI askpass so, nevermind. You can
> > try to kill the ssh sub-process?
