[Swift-devel] command line ssh provider...
Mihael Hategan
hategan at mcs.anl.gov
Mon Jan 16 13:14:17 CST 2012
On Mon, 2012-01-16 at 13:10 -0600, Jonathan Monette wrote:
> as the first parameter in the ArrayList. However I cannot make
> anything show up in the logs. I tried entering in the wrong password
> as well as the correct password. Is there anything else that needs to
> be added to the JobSubmissionTaskHandler file? Or where else should I
> look besides the logs?
You need to type some wrong password to make the job fail which captures
the output.
