[Swift-devel] command line ssh provider...
Michael Wilde wilde at mcs.anl.gov
Thu Jan 12 21:19:36 CST 2012
The boostrap log shows this:
com$ cat ~/coaster-bootstrap-1460623968.log
using plain mode
BS: http://communicado.ci.uchicago.edu:45621
Failed to download bootstrap jar from http://communicado.ci.uchicago.edu:45621
com$
- Mike
----- Original Message -----
> From: "Mihael Hategan" <hategan at mcs.anl.gov>
> To: "Michael Wilde" <wilde at mcs.anl.gov>
> Cc: "Jonathan Monette" <jonmon at mcs.anl.gov>, "Swift Devel" <swift-devel at ci.uchicago.edu>
> Sent: Thursday, January 12, 2012 8:34:36 PM
> Subject: Re: [Swift-devel] command line ssh provider...
> Can't test it right now because UCDavis decided to firewall stuff, but
> I
> do get the bootstrap script to start and it gets to the wget part.
> So the question is, do you get a bootstrap log?
> On Thu, 2012-01-12 at 13:45 -0600, Michael Wilde wrote:
> > ssh-cl worked for me going from communicado to both login.ci and
> > bridled.
> > I *assumed* it used my agent because I did not get a password prompt
> > from the swift run. And I dont get a password prompt when running
> > the ssh command line.
> > It failed when I tried to use coasters with either provider staging
> > (to login.mcs) or localhost/shared workdir (to login.ci).
> > The command line and stdout/err for the coaster/local-workdir case
> > is below. The logs are on ci net under ~wilde/swift/lab. Config and
> > sites file was:
> > com$ cat cf
> > wrapperlog.always.transfer=true
> > sitedir.keep=true
> > execution.retries=0
> > lazy.errors=false
> > status.mode=provider
> > use.provider.staging=false
> > provider.staging.pin.swiftfiles=false
> > com$ cat sshcl.xml
> > <config>
> >   <pool handle="localhost">
> >     <execution provider="ssh-cl" url="login.ci.uchicago.edu"/>
> >     <filesystem provider="local"/>
> >     <workdirectory>/home/wilde/swiftwork</workdirectory>
> >   </pool>
> > </config>
> > com$
> > com$ cat sshclcoast.xml
> > <config>
> >     <execution provider="coaster" url="login.ci.uchicago.edu"
> >     jobmanager="ssh-cl:local"/>
> >     <profile namespace="globus" key="jobsPerNode">8</profile>
> >     <profile namespace="globus" key="slots">1</profile>
> >     <profile namespace="globus" key="nodeGranularity">1</profile>
> >     <profile namespace="globus" key="maxNodes">1</profile>
> >     <profile namespace="karajan" key="jobThrottle">.01</profile>
> >     <profile namespace="karajan" key="initialScore">10000</profile>
> >   </pool>
> > </config>
> > com$
> > - Mike
> > com$ which swift
> > ~/swift/src/trunk/cog/modules/swift/dist/swift-svn/bin/swift
> > com$ pwd
> > /home/wilde/swift/lab
> > com$ swift -tc.file tc -sites.file sshcl.xml -config cf catsn.swift
> > -n=1
> > Swift trunk swift-r5498 cog-r3347
> > RunID: 20120112-1343-a7mk2zyc
> > Progress: time: Thu, 12 Jan 2012 13:43:04 -0600
> > Final status: Thu, 12 Jan 2012 13:43:04 -0600 Finished
> > successfully:1
> > com$ swift -tc.file tc -sites.file sshclcoast.xml -config cf
> > catsn.swift -n=1
> > RunID: 20120112-1343-ql7sn3f7
> > Progress: time: Thu, 12 Jan 2012 13:43:20 -0600
> > Failed to transfer wrapper log for job cat-ihhm6jlk
> > EXCEPTION Exception in cat:
> > Arguments: [data.txt]
> > Host: localhost
> > Directory: catsn-20120112-1343-ql7sn3f7/jobs/i/cat-ihhm6jlk
> > stderr.txt:
> > stdout.txt:
> > Caused by: null
> > Caused by:
> > org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> > Could not submit job
> > Caused by:
> > Could not start coaster service
> > Caused by:
> > Task ended before registration was received.
> > STDOUT: Failed to download bootstrap jar from
> > STDERR: This machine accepts SSH public key and One Time Password
> > (OTP) logins only.
> > If you do not have a public key set up, you will be prompted for a
> > password.
> > This is *not* your CI password, but the One Time Password generated
> > from your
> > OTP token. Do not type your CI password, it will not work. If you do
> > not
> > have a token or public key, you will not be able to login.
> > See http://www.ci.uchicago.edu/faq for more information.
> > Caused by:
> > org.globus.cog.abstraction.impl.common.execution.JobException: Job
> > failed with an exit code of 1
> > Execution failed:
> > 	Job failed with an exit code of 1
> > com$
> > > From: "Jonathan Monette" <jonmon at mcs.anl.gov>
> > > To: "Mihael Hategan" <hategan at mcs.anl.gov>
> > > Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>, "Michael Wilde"
> > > Sent: Thursday, January 12, 2012 1:29:10 PM
> > > Mike,
> > > You mentioned that you were able to use ssh command line provider
> > > using catsn this morning. Was it using agents? Mihael did you test
> > > using an agent? How do I specify for it to use an agent if
> > > available?
> > > I can do a simple hostname test from communicado to bridled but it
> > > asks for my password instead of using the agent I have set up.
> > > On Jan 12, 2012, at 12:21 AM, Mihael Hategan wrote:
> > > > ... is in trunk (cog r3347). I was able to start coasters with
> > > > it.
> > > > The
> > > > provider is called "ssh-cl". It is ssh, so ~/.ssh/config and
> > > > agents
> > > > will
> > > > apply. Please test.
> > > > Mihael
> > > > _______________________________________________
> > > > Swift-devel mailing list
> > > > Swift-devel at ci.uchicago.edu
> > > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
