[Swift-devel] command line ssh provider...
Mihael Hategan
hategan at mcs.anl.gov
Thu Jan 12 20:34:36 CST 2012
Can't test it right now because UCDavis decided to firewall stuff, but I
do get the bootstrap script to start and it gets to the wget part.
So the question is, do you get a bootstrap log?
On Thu, 2012-01-12 at 13:45 -0600, Michael Wilde wrote:
> ssh-cl worked for me going from communicado to both login.ci and bridled.
> I *assumed* it used my agent because I did not get a password prompt from the swift run. And I dont get a password prompt when running the ssh command line.
> It failed when I tried to use coasters with either provider staging (to login.mcs) or localhost/shared workdir (to login.ci).
> The command line and stdout/err for the coaster/local-workdir case is below. The logs are on ci net under ~wilde/swift/lab. Config and sites file was:
> com$ cat cf
> wrapperlog.always.transfer=true
> sitedir.keep=true
> execution.retries=0
> lazy.errors=false
> status.mode=provider
> use.provider.staging=false
> provider.staging.pin.swiftfiles=false
> com$ cat sshcl.xml
> <config>
> <pool handle="localhost">
> <execution provider="ssh-cl" url="login.ci.uchicago.edu"/>
> <filesystem provider="local"/>
> <workdirectory>/home/wilde/swiftwork</workdirectory>
> </pool>
> </config>
> com$
> com$ cat sshclcoast.xml
> <config>
> <execution provider="coaster" url="login.ci.uchicago.edu" jobmanager="ssh-cl:local"/>
> <profile namespace="globus" key="jobsPerNode">8</profile>
> <profile namespace="globus" key="slots">1</profile>
> <profile namespace="globus" key="nodeGranularity">1</profile>
> <profile namespace="globus" key="maxNodes">1</profile>
> <profile namespace="karajan" key="jobThrottle">.01</profile>
> <profile namespace="karajan" key="initialScore">10000</profile>
> </pool>
> </config>
> com$
> - Mike
> com$ which swift
> ~/swift/src/trunk/cog/modules/swift/dist/swift-svn/bin/swift
> com$ pwd
> /home/wilde/swift/lab
> com$ swift -tc.file tc -sites.file sshcl.xml -config cf catsn.swift -n=1
> Swift trunk swift-r5498 cog-r3347
> RunID: 20120112-1343-a7mk2zyc
> Progress: time: Thu, 12 Jan 2012 13:43:04 -0600
> Final status: Thu, 12 Jan 2012 13:43:04 -0600 Finished successfully:1
> com$ swift -tc.file tc -sites.file sshclcoast.xml -config cf catsn.swift -n=1
> RunID: 20120112-1343-ql7sn3f7
> Progress: time: Thu, 12 Jan 2012 13:43:20 -0600
> Failed to transfer wrapper log for job cat-ihhm6jlk
> EXCEPTION Exception in cat:
> Arguments: [data.txt]
> Host: localhost
> Directory: catsn-20120112-1343-ql7sn3f7/jobs/i/cat-ihhm6jlk
> stderr.txt:
> stdout.txt:
> Caused by: null
> Caused by: org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Could not submit job
> Caused by: org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Could not start coaster service
> Caused by: org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Task ended before registration was received.
> STDOUT: Failed to download bootstrap jar from http://communicado.ci.uchicago.edu:45621
> STDERR: This machine accepts SSH public key and One Time Password (OTP) logins only.
> If you do not have a public key set up, you will be prompted for a password.
> This is *not* your CI password, but the One Time Password generated from your
> OTP token. Do not type your CI password, it will not work. If you do not
> have a token or public key, you will not be able to login.
> See http://www.ci.uchicago.edu/faq for more information.
> Caused by: org.globus.cog.abstraction.impl.common.execution.JobException: Job failed with an exit code of 1
> Execution failed:
> com$
> > From: "Jonathan Monette" <jonmon at mcs.anl.gov>
> > To: "Mihael Hategan" <hategan at mcs.anl.gov>
> > Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>, "Michael Wilde" <wilde at mcs.anl.gov>
> > Sent: Thursday, January 12, 2012 1:29:10 PM
> > Subject: Re: [Swift-devel] command line ssh provider...
> > Mike,
> > You mentioned that you were able to use ssh command line provider
> > using catsn this morning. Was it using agents? Mihael did you test
> > using an agent? How do I specify for it to use an agent if available?
> > I can do a simple hostname test from communicado to bridled but it
> > asks for my password instead of using the agent I have set up.
> > On Jan 12, 2012, at 12:21 AM, Mihael Hategan wrote:
> > > ... is in trunk (cog r3347). I was able to start coasters with it.
> > > The
> > > provider is called "ssh-cl". It is ssh, so ~/.ssh/config and agents
> > > will
> > > apply. Please test.
> > > Mihael
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
