[Swift-devel] command line ssh provider...
Ketan Maheshwari
ketancmaheshwari at gmail.com
Thu Jan 12 21:23:58 CST 2012
This would be because of firewall at communicado. Probably need to set
GLOBUS_TCP_PORT_RANGE=50000,51000
On Thu, Jan 12, 2012 at 9:19 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> The boostrap log shows this:
> com$ cat ~/coaster-bootstrap-1460623968.log
> using plain mode
> BS: http://communicado.ci.uchicago.edu:45621
> Failed to download bootstrap jar from
> com$
> - Mike
> > From: "Mihael Hategan" <hategan at mcs.anl.gov>
> > To: "Michael Wilde" <wilde at mcs.anl.gov>
> > Cc: "Jonathan Monette" <jonmon at mcs.anl.gov>, "Swift Devel" <
> swift-devel at ci.uchicago.edu>
> > Sent: Thursday, January 12, 2012 8:34:36 PM
> > Subject: Re: [Swift-devel] command line ssh provider...
> > Can't test it right now because UCDavis decided to firewall stuff, but
> > I
> > do get the bootstrap script to start and it gets to the wget part.
> > So the question is, do you get a bootstrap log?
> > On Thu, 2012-01-12 at 13:45 -0600, Michael Wilde wrote:
> > > ssh-cl worked for me going from communicado to both login.ci and
> > > bridled.
> > > I *assumed* it used my agent because I did not get a password prompt
> > > from the swift run. And I dont get a password prompt when running
> > > the ssh command line.
> > > It failed when I tried to use coasters with either provider staging
> > > (to login.mcs) or localhost/shared workdir (to login.ci).
> > > The command line and stdout/err for the coaster/local-workdir case
> > > is below. The logs are on ci net under ~wilde/swift/lab. Config and
> > > sites file was:
> > > com$ cat cf
> > > wrapperlog.always.transfer=true
> > > sitedir.keep=true
> > > execution.retries=0
> > > lazy.errors=false
> > > status.mode=provider
> > > use.provider.staging=false
> > > provider.staging.pin.swiftfiles=false
> > > com$ cat sshcl.xml
> > > <config>
> > > <pool handle="localhost">
> > > <execution provider="ssh-cl" url="login.ci.uchicago.edu"/>
> > > <filesystem provider="local"/>
> > > <workdirectory>/home/wilde/swiftwork</workdirectory>
> > > </pool>
> > > </config>
> > > com$
> > > com$ cat sshclcoast.xml
> > > <config>
> > > <execution provider="coaster" url="login.ci.uchicago.edu"
> > > jobmanager="ssh-cl:local"/>
> > > <profile namespace="globus" key="jobsPerNode">8</profile>
> > > <profile namespace="globus" key="slots">1</profile>
> > > <profile namespace="globus" key="nodeGranularity">1</profile>
> > > <profile namespace="globus" key="maxNodes">1</profile>
> > > <profile namespace="karajan" key="jobThrottle">.01</profile>
> > > <profile namespace="karajan" key="initialScore">10000</profile>
> > > </pool>
> > > </config>
> > > com$
> > > - Mike
> > > com$ which swift
> > > ~/swift/src/trunk/cog/modules/swift/dist/swift-svn/bin/swift
> > > com$ pwd
> > > /home/wilde/swift/lab
> > > com$ swift -tc.file tc -sites.file sshcl.xml -config cf catsn.swift
> > > -n=1
> > > Swift trunk swift-r5498 cog-r3347
> > > RunID: 20120112-1343-a7mk2zyc
> > > Progress: time: Thu, 12 Jan 2012 13:43:04 -0600
> > > Final status: Thu, 12 Jan 2012 13:43:04 -0600 Finished
> > > successfully:1
> > > com$ swift -tc.file tc -sites.file sshclcoast.xml -config cf
> > > catsn.swift -n=1
> > > RunID: 20120112-1343-ql7sn3f7
> > > Progress: time: Thu, 12 Jan 2012 13:43:20 -0600
> > > Failed to transfer wrapper log for job cat-ihhm6jlk
> > > EXCEPTION Exception in cat:
> > > Arguments: [data.txt]
> > > Host: localhost
> > > Directory: catsn-20120112-1343-ql7sn3f7/jobs/i/cat-ihhm6jlk
> > > stderr.txt:
> > > stdout.txt:
> > > Caused by: null
> > > Caused by:
> > > org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> > > Could not submit job
> > > Caused by:
> > > Could not start coaster service
> > > Caused by:
> > > Task ended before registration was received.
> > > STDOUT: Failed to download bootstrap jar from
> > > STDERR: This machine accepts SSH public key and One Time Password
> > > (OTP) logins only.
> > > If you do not have a public key set up, you will be prompted for a
> > > password.
> > > This is *not* your CI password, but the One Time Password generated
> > > from your
> > > OTP token. Do not type your CI password, it will not work. If you do
> > > not
> > > have a token or public key, you will not be able to login.
> > > See http://www.ci.uchicago.edu/faq for more information.
> > > Caused by:
> > > org.globus.cog.abstraction.impl.common.execution.JobException: Job
> > > failed with an exit code of 1
> > > Execution failed:
> > > Job failed with an exit code of 1
> > > com$
> > > > From: "Jonathan Monette" <jonmon at mcs.anl.gov>
> > > > To: "Mihael Hategan" <hategan at mcs.anl.gov>
> > > > Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>, "Michael Wilde"
> > > > Sent: Thursday, January 12, 2012 1:29:10 PM
> > > > Mike,
> > > > You mentioned that you were able to use ssh command line provider
> > > > using catsn this morning. Was it using agents? Mihael did you test
> > > > using an agent? How do I specify for it to use an agent if
> > > > available?
> > > > I can do a simple hostname test from communicado to bridled but it
> > > > asks for my password instead of using the agent I have set up.
> > > > On Jan 12, 2012, at 12:21 AM, Mihael Hategan wrote:
> > > > > ... is in trunk (cog r3347). I was able to start coasters with
> > > > > it.
> > > > > The
> > > > > provider is called "ssh-cl". It is ssh, so ~/.ssh/config and
> > > > > agents
> > > > > will
> > > > > apply. Please test.
> > > > > Mihael
> > > > > _______________________________________________
> > > > > Swift-devel mailing list
> > > > > Swift-devel at ci.uchicago.edu
> > > > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20120112/3ce329c3/attachment.html>
