[Swift-devel] command line ssh provider...
Jonathan Monette jonmon at mcs.anl.gov
Thu Jan 12 13:34:20 CST 2012
Thanks.  I'll try that in the meantime.
On Jan 12, 2012, at 1:33 PM, Mihael Hategan wrote:
> On Thu, 2012-01-12 at 13:29 -0600, Jonathan Monette wrote:
>> Mike,
>>   You mentioned that you were able to use ssh command line provider
>> using catsn this morning.  Was it using agents?  Mihael did you test
>> using an agent?  How do I specify for it to use an agent if available?
>> I can do a simple hostname test from communicado to bridled but it
>> asks for my password instead of using the agent I have set up.
> Yes, it was using an agent.
> I'll add a flag to enable ssh debugging so that we can see exactly
> what's happening. You can probably
> hack ...sshcl.JobSubmissionTaskHandler to add a bunch of "-v" arguments
> to ssh in the mean time.
