[Swift-devel] command line ssh provider...
Mihael Hategan
hategan at mcs.anl.gov
Thu Jan 12 13:40:54 CST 2012
To actually get the stdout you should make the job fail somehow. Maybe
by typing the wrong password.
On Thu, 2012-01-12 at 13:34 -0600, Jonathan Monette wrote:
> Thanks. I'll try that in the meantime.
> On Jan 12, 2012, at 1:33 PM, Mihael Hategan wrote:
> > On Thu, 2012-01-12 at 13:29 -0600, Jonathan Monette wrote:
> >> Mike,
> >> You mentioned that you were able to use ssh command line provider
> >> using catsn this morning. Was it using agents? Mihael did you test
> >> using an agent? How do I specify for it to use an agent if available?
> >> I can do a simple hostname test from communicado to bridled but it
> >> asks for my password instead of using the agent I have set up.
> > Yes, it was using an agent.
> > I'll add a flag to enable ssh debugging so that we can see exactly
> > what's happening. You can probably
> > hack ...sshcl.JobSubmissionTaskHandler to add a bunch of "-v" arguments
> > to ssh in the mean time.
