[Swift-devel] command line ssh provider...
Mihael Hategan hategan at mcs.anl.gov
Thu Jan 12 13:33:17 CST 2012
On Thu, 2012-01-12 at 13:29 -0600, Jonathan Monette wrote:
> Mike,
>    You mentioned that you were able to use ssh command line provider
> using catsn this morning.  Was it using agents?  Mihael did you test
> using an agent?  How do I specify for it to use an agent if available?
> I can do a simple hostname test from communicado to bridled but it
> asks for my password instead of using the agent I have set up.
Yes, it was using an agent.
I'll add a flag to enable ssh debugging so that we can see exactly
what's happening. You can probably
hack ...sshcl.JobSubmissionTaskHandler to add a bunch of "-v" arguments
to ssh in the mean time.
