[Swift-devel] command line ssh provider...
Jonathan Monette
jonmon at mcs.anl.gov
Thu Jan 12 13:29:10 CST 2012
Mike,
You mentioned that you were able to use ssh command line provider using catsn this morning. Was it using agents? Mihael did you test using an agent? How do I specify for it to use an agent if available? I can do a simple hostname test from communicado to bridled but it asks for my password instead of using the agent I have set up.
On Jan 12, 2012, at 12:21 AM, Mihael Hategan wrote:
> ... is in trunk (cog r3347). I was able to start coasters with it. The
> provider is called "ssh-cl". It is ssh, so ~/.ssh/config and agents will
> apply. Please test.
> Mihael
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
