[Swift-devel] Walltime exceeded error
    Jonathan Monette
    jonmon at mcs.anl.gov
    Fri Feb 24 16:09:54 CST 2012
I have updated the bugzilla bug with the below directories: https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=720
I have also added another directory showing the same behavior
/gpfs/pads/swift/jonmon/Swift/bugs/SciColSim/run054
There is a jstack.log file in that directory.  All three of the run directories show that jobs get stuck in the initialized state and the hang checker kicks in.
On Feb 22, 2012, at 5:05 PM, Jonathan Monette wrote:
> This has been done.  I have also moved the run that Ketan had produced to PADS.
> /gpfs/pads/swift/jonmon/Swift/bugs/SciColSim/run002    <-----Ketan's run
> /gpfs/pads/swift/jonmon/Swift/bugs/SciColSim/run047    <-----My run(has a jstack.log file, also more recent)
> On Feb 22, 2012, at 4:33 PM, Jonathan Monette wrote:
>> Ok.  I have killed the process and I am in the process of copying the run directory from the lustre file system on Beagle to /gpfs/pads
>> On Feb 22, 2012, at 4:28 PM, Mihael Hategan wrote:
>>> On Wed, 2012-02-22 at 15:45 -0600, Jonathan Monette wrote:
>>>> Mihael,
>>>> I have a hung Java process showing this error right now, 2 jobs are
>>>> stuck in the initializing state.  I have a jstack -l <pid> of this
>>>> hung java process.  Is there anything else you need before I kill it?
>>>> Do you need any other probing information from this process other than
>>>> this jstack output?
>>> I don't think so.
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20120224/21719ec6/attachment.html>
