[Swift-devel] Walltime exceeded error
    Jonathan Monette
    jonmon at mcs.anl.gov
    Wed Feb 22 17:05:40 CST 2012
This has been done.  I have also moved the run that Ketan had produced to PADS.
/gpfs/pads/swift/jonmon/Swift/bugs/SciColSim/run002    <-----Ketan's run
/gpfs/pads/swift/jonmon/Swift/bugs/SciColSim/run047    <-----My run(has a jstack.log file, also more recent)
On Feb 22, 2012, at 4:33 PM, Jonathan Monette wrote:
> Ok.  I have killed the process and I am in the process of copying the run directory from the lustre file system on Beagle to /gpfs/pads
> On Feb 22, 2012, at 4:28 PM, Mihael Hategan wrote:
>> On Wed, 2012-02-22 at 15:45 -0600, Jonathan Monette wrote:
>>> Mihael,
>>>  I have a hung Java process showing this error right now, 2 jobs are
>>> stuck in the initializing state.  I have a jstack -l <pid> of this
>>> hung java process.  Is there anything else you need before I kill it?
>>> Do you need any other probing information from this process other than
>>> this jstack output?
>> I don't think so.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
