[Swift-devel] How to increase Swift-coaster task rate
Ketan Maheshwari ketancmaheshwari at gmail.com
Thu Apr 26 21:07:45 CDT 2012
One thing that could be checked is the JVM. Cray's default java appears to
be IBM. If the benchmark is not already running on IBM java, it could be
tested to see if better performance is achieved.
On Thu, Apr 26, 2012 at 9:37 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Mihael,
> David, Jon, and I are working on Cray benchmarks for a paper for the Cray
> Users Group.
> In tests so far, we are being limited by job submission rates of about 80
> tasks/sec.
> We'd like very much to drive that up closer to 200/sec if at all possible
> for the benchmarks we're trying to run.
> The current tests are doing sleep 0 jobs with no file transfer to about
> 2400 cores on a Cray benchmark system. The workdir is set to /dev/shm. The
> throttles are almost all set way up (Jon can post the specific config and
> values).
> One thing we have not yet done is try to get the log traffic way down;
> thats next up to try.
> We'll revert to testing against 480 cores on raven for now. That should
> still be enough to push the upper limit of Swift, Karajan and coasters.
> Can you give us a set of things to check (set, turn off, etc) to try to
> get closer to 200 tasks/sec? Do we need to set <scratch> to /dev/shm in
> addition to work dir?
> This latest run was I think with provider staging and pin coaster files.
> Thanks,
> - Mike
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20120426/7ac500b0/attachment.html>
