[Swift-devel] hanging in trunk
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Apr  3 02:15:09 CDT 2012
r5141 was relevant though. I committed that to trunk. Please test.
On Tue, 2012-04-03 at 00:07 -0700, Mihael Hategan wrote:
> Hmm, so the deadlock in the jstack file and r5143 do not cross paths. So
> you're probably seeing things working because they sometimes do not
> because of the code change.
> On Mon, 2012-04-02 at 22:48 -0500, Jonathan Monette wrote:
> > Yea. I ran small tests to see if this fixed it. Before it hung almost immediately. The small tests did not hang. I currently have a larger test waiting to be executed on raven. Seems the machine is I'm full use right now.
> > On Apr 2, 2012, at 21:39, David Kelly <davidk at ci.uchicago.edu> wrote:
> > > It looks like that particular fix was only applied to 0.93.. perhaps it was missed when doing the merges.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
