[Swift-devel] hanging in trunk
    Jonathan Monette
    jonmon at mcs.anl.gov
    Tue Apr  3 10:38:03 CDT 2012
You were correct.  The workflow still hung it just took longer in the run I ran.
So this is what I will do for my the SciColSim app.  I will port the socket and pipe fix to the 0.93 branch and compile my own release for it while the issue is worked out in trunk.  When trunk is believed to be fixed, let me know and I can do my testing.
On Apr 3, 2012, at 2:07 AM, Mihael Hategan wrote:
> Hmm, so the deadlock in the jstack file and r5143 do not cross paths. So
> you're probably seeing things working because they sometimes do not
> because of the code change.
> On Mon, 2012-04-02 at 22:48 -0500, Jonathan Monette wrote:
>> Yea. I ran small tests to see if this fixed it. Before it hung almost immediately. The small tests did not hang. I currently have a larger test waiting to be executed on raven. Seems the machine is I'm full use right now.
>> On Apr 2, 2012, at 21:39, David Kelly <davidk at ci.uchicago.edu> wrote:
>>> It looks like that particular fix was only applied to 0.93.. perhaps it was missed when doing the merges.
