[Swift-devel] hanging in trunk
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Apr  3 02:07:24 CDT 2012
Hmm, so the deadlock in the jstack file and r5143 do not cross paths. So
you're probably seeing things working because they sometimes do not
because of the code change.
On Mon, 2012-04-02 at 22:48 -0500, Jonathan Monette wrote:
> Yea. I ran small tests to see if this fixed it. Before it hung almost immediately. The small tests did not hang. I currently have a larger test waiting to be executed on raven. Seems the machine is I'm full use right now.
> On Apr 2, 2012, at 21:39, David Kelly <davidk at ci.uchicago.edu> wrote:
> > It looks like that particular fix was only applied to 0.93.. perhaps it was missed when doing the merges.
