[Swift-devel] Application run scripts
    Jonathan Monette
    jon.monette at gmail.com
    Mon Apr  2 15:54:53 CDT 2012
Yes.  Generalizing swiftopt.sh to a general runswift script that any application can use.
On Apr 2, 2012, at 1:38 PM, Justin M Wozniak wrote:
> Is this about swiftopt.sh ?
> On Mon, 2 Apr 2012, Jonathan Monette wrote:
>> I have already been working on a run script using the logic we have from
>> SciColSim.  It is not checked in for testing as it still only works for
>> SciColSim.  I have been looking for other run scripts I have laying
>> around to see what is still missing and how to work with @arg
>> parameters.  Right now it just sources a parameter file but I want to
>> also have the ability to pass in the parameters on the command line as
>> it seems kind of clunky to make a parameter file if you only need 1 or 2
>> parameters set.
>> So when you finish the CMTS script please provide a pointer.  I can then
>> compare the one I have and the one you have and do a check in for
>> testing for a wide variety of apps.  We can get this into trunk and
>> stabilize the script for a 0.94 release.
>> On Apr 2, 2012, at 12:04 PM, Michael Wilde wrote:
>>> Jon, David,
>>> I am cloning the user run script we did for SciCol for the first CMTS
>>> application ("energy landscape").
>>> Im a bit concerned that if we dont do something soon to create a nice
>>> separation between application-independent "Swift run logic" and the
>>> application-specific logic, we'll forever be re-writing the common code
>>> and making the user code more complex, hard to document, etc.
>>> This is just a heads-up that I'm looking for ideas on how to do this in
>>> a nice way that we can immediately test on SciCol, DSSAT, CMTS,
>>> Broadband, etc. and ideally leverage in GO-Swift.
>>> Mike
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Justin M Wozniak
