[Swift-devel] Application run scripts
    Justin M Wozniak
    wozniak at mcs.anl.gov
    Mon Apr  2 13:38:59 CDT 2012
Is this about swiftopt.sh ?
On Mon, 2 Apr 2012, Jonathan Monette wrote:
> I have already been working on a run script using the logic we have from
> SciColSim.  It is not checked in for testing as it still only works for
> SciColSim.  I have been looking for other run scripts I have laying
> around to see what is still missing and how to work with @arg
> parameters.  Right now it just sources a parameter file but I want to
> also have the ability to pass in the parameters on the command line as
> it seems kind of clunky to make a parameter file if you only need 1 or 2
> parameters set.
> So when you finish the CMTS script please provide a pointer.  I can then
> compare the one I have and the one you have and do a check in for
> testing for a wide variety of apps.  We can get this into trunk and
> stabilize the script for a 0.94 release.
> On Apr 2, 2012, at 12:04 PM, Michael Wilde wrote:
>> Jon, David,
>> I am cloning the user run script we did for SciCol for the first CMTS
>> application ("energy landscape").
>> Im a bit concerned that if we dont do something soon to create a nice
>> separation between application-independent "Swift run logic" and the
>> application-specific logic, we'll forever be re-writing the common code
>> and making the user code more complex, hard to document, etc.
>> This is just a heads-up that I'm looking for ideas on how to do this in
>> a nice way that we can immediately test on SciCol, DSSAT, CMTS,
>> Broadband, etc. and ideally leverage in GO-Swift.
>> Mike
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Justin M Wozniak
