[Swift-devel] Application run scripts
    Jonathan Monette
    jon.monette at gmail.com
    Mon Apr  2 12:21:20 CDT 2012
I have already been working on a run script using the logic we have from SciColSim.  It is not checked in for testing as it still only works for SciColSim.  I have been looking for other run scripts I have laying around to see what is still missing and how to work with @arg parameters.  Right now it just sources a parameter file but I want to also have the ability to pass in the parameters on the command line as it seems kind of clunky to make a parameter file if you only need 1 or 2 parameters set.
So when you finish the CMTS script please provide a pointer.  I can then compare the one I have and the one you have and do a check in for testing for a wide variety of apps.  We can get this into trunk and stabilize the script for a 0.94 release.
On Apr 2, 2012, at 12:04 PM, Michael Wilde wrote:
> Jon, David,
> I am cloning the user run script we did for SciCol for the first CMTS application ("energy landscape").
> Im a bit concerned that if we dont do something soon to create a nice separation between application-independent "Swift run logic" and the application-specific logic, we'll forever be re-writing the common code and making the user code more complex, hard to document, etc.
> This is just a heads-up that I'm looking for ideas on how to do this in a nice way that we can immediately test on SciCol, DSSAT, CMTS, Broadband, etc. and ideally leverage in GO-Swift.
> Mike
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
