[Swift-devel] persistent coasters gridftp provider fails with	error 500
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Sep 22 18:03:11 CDT 2011
Does that machine have /bin/bash?
The failure to transfer the wrapper log is normal, since the wrapper
didn't actually run, but it is not the source of the problem.
On Thu, 2011-09-22 at 15:56 -0500, Ketan Maheshwari wrote:
> Hi Mihael,
> I was trying to use persistent coasters on OSG with gridFTP as
> provider. The script catsn is intended to transfer one small file
> (<1MB) to an OSG site (gsiftp://cit-gatekeeper.ultralight.org).
> However, I see that the script fails. The stdout message is:
> Failed to transfer wrapper log for job cat-tyxj0agk
> Progress:  time: Thu, 22 Sep 2011 15:44:35 -0500  Failed:1
> Exception in cat:
> Arguments: [gpfs/pads/swift/ketan/indir1file/data0000.txt]
> Host: CIT_CMS_T2__cit-gatekeeper.ultralight.org
> Directory: catsngridftp-20110922-1544-brgdcf5d/jobs/t/cat-tyxj0agk
> stderr.txt:
> stdout.txt:
> Caused by: null
> Caused by:
> org.globus.cog.abstraction.impl.common.execution.JobException: Job
> failed with an exit code of 127
> Final status:  time: Thu, 22 Sep 2011 15:44:35 -0500  Failed:1
> The following errors have occurred:
> 1. Job failed with an exit code of 127
> Looking at the log it says the following error:
> 2011-09-22 15:44:35,716-0500 DEBUG vdl:transferwrapperlog Exception
> for wrapper log failure from
> catsngridftp-20110922-1544-brgdcf5d/info/t on CIT_CMS_T2__cit-gateke
> eper.ultralight.org: null
> Caused by:
> org.globus.cog.abstraction.impl.file.IrrecoverableResourceException:
> Exception in getFile
> Caused by: org.globus.cog.abstraction.impl.file.FileResourceException:
> Failed to retrieve file information
> about /raid2/osg-data/engage/scec/swift_scratch/catsngridf
> tp-20110922-1544-brgdcf5d/info/t/cat-tyxj0agk-info
> Caused by: org.globus.ftp.exception.ServerException: Server refused
> performing the request. Custom message: Server refused MLST command
> (error code 1) [Nested except
> ion message:  Custom message: Unexpected reply: 500-Command failed :
> globus_gridftp_server_file.c:globus_l_gfs_file_stat:389:
> 500-System error in stat: No such file or directory
> 500-A system call failed: No such file or directory
> 500 End.] [Nested exception is
> org.globus.ftp.exception.UnexpectedReplyCodeException:  Custom
> 500 End.]
> 2011-09-22 15:44:35,719-0500 INFO  vdl:execute END_FAILURE
> thread=0-6-0-1 tr=cat
> 2011-09-22 15:44:35,720-0500 INFO  vdl:execute Exception in cat:
> I manually tried to transfer files of small sizes to and from pads to
> the site in question and it worked ok.
> The complete log for this run is:
> http://www.ci.uchicago.edu/~ketan/catsngridftp-20110922-1544-brgdcf5d.log
> Could you kindly study the log and give any clues as to what is going
> on.
> Regards,
> Ketan
