[Swift-devel] persistent coasters gridftp provider fails with	error 500
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Thu Sep 22 21:10:24 CDT 2011
On Thu, Sep 22, 2011 at 6:03 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Does that machine have /bin/bash?
yes.
[bridled:catsn-condor]$ globus-job-run
cit-gatekeeper.ultralight.org/bin/bash -c '/bin/hostname'
cithep231.ultralight.org
> The failure to transfer the wrapper log is normal, since the wrapper
> didn't actually run, but it is not the source of the problem.
> On Thu, 2011-09-22 at 15:56 -0500, Ketan Maheshwari wrote:
> > Hi Mihael,
> > I was trying to use persistent coasters on OSG with gridFTP as
> > provider. The script catsn is intended to transfer one small file
> > (<1MB) to an OSG site (gsiftp://cit-gatekeeper.ultralight.org).
> > However, I see that the script fails. The stdout message is:
> > Failed to transfer wrapper log for job cat-tyxj0agk
> > Progress:  time: Thu, 22 Sep 2011 15:44:35 -0500  Failed:1
> > Exception in cat:
> > Arguments: [gpfs/pads/swift/ketan/indir1file/data0000.txt]
> > Host: CIT_CMS_T2__cit-gatekeeper.ultralight.org
> > Directory: catsngridftp-20110922-1544-brgdcf5d/jobs/t/cat-tyxj0agk
> > stderr.txt:
> > stdout.txt:
> > Caused by: null
> > Caused by:
> > org.globus.cog.abstraction.impl.common.execution.JobException: Job
> > failed with an exit code of 127
> > Final status:  time: Thu, 22 Sep 2011 15:44:35 -0500  Failed:1
> > The following errors have occurred:
> > 1. Job failed with an exit code of 127
> > Looking at the log it says the following error:
> > 2011-09-22 15:44:35,716-0500 DEBUG vdl:transferwrapperlog Exception
> > for wrapper log failure from
> > catsngridftp-20110922-1544-brgdcf5d/info/t on CIT_CMS_T2__cit-gateke
> > eper.ultralight.org: null
> > Caused by:
> > org.globus.cog.abstraction.impl.file.IrrecoverableResourceException:
> > Exception in getFile
> > Caused by: org.globus.cog.abstraction.impl.file.FileResourceException:
> > Failed to retrieve file information
> > about /raid2/osg-data/engage/scec/swift_scratch/catsngridf
> > tp-20110922-1544-brgdcf5d/info/t/cat-tyxj0agk-info
> > Caused by: org.globus.ftp.exception.ServerException: Server refused
> > performing the request. Custom message: Server refused MLST command
> > (error code 1) [Nested except
> > ion message:  Custom message: Unexpected reply: 500-Command failed :
> > globus_gridftp_server_file.c:globus_l_gfs_file_stat:389:
> > 500-System error in stat: No such file or directory
> > 500-A system call failed: No such file or directory
> > 500 End.] [Nested exception is
> > org.globus.ftp.exception.UnexpectedReplyCodeException:  Custom
> > 500 End.]
> > 2011-09-22 15:44:35,719-0500 INFO  vdl:execute END_FAILURE
> > thread=0-6-0-1 tr=cat
> > 2011-09-22 15:44:35,720-0500 INFO  vdl:execute Exception in cat:
> > I manually tried to transfer files of small sizes to and from pads to
> > the site in question and it worked ok.
> > The complete log for this run is:
> http://www.ci.uchicago.edu/~ketan/catsngridftp-20110922-1544-brgdcf5d.log
> > Could you kindly study the log and give any clues as to what is going
> > on.
> > Regards,
> > Ketan
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110922/b90b7fd8/attachment.html>
