[Swift-devel] persistent coasters gridftp provider fails with error	500
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Thu Sep 22 15:56:38 CDT 2011
Hi Mihael,
I was trying to use persistent coasters on OSG with gridFTP as provider. The
script catsn is intended to transfer one small file (<1MB) to an OSG site
(gsiftp://cit-gatekeeper.ultralight.org).
However, I see that the script fails. The stdout message is:
Failed to transfer wrapper log for job cat-tyxj0agk
Progress:  time: Thu, 22 Sep 2011 15:44:35 -0500  Failed:1
Exception in cat:
Arguments: [gpfs/pads/swift/ketan/indir1file/data0000.txt]
Host: CIT_CMS_T2__cit-gatekeeper.ultralight.org
Directory: catsngridftp-20110922-1544-brgdcf5d/jobs/t/cat-tyxj0agk
stderr.txt:
stdout.txt:
Caused by: null
Caused by: org.globus.cog.abstraction.impl.common.execution.JobException:
Job failed with an exit code of 127
Final status:  time: Thu, 22 Sep 2011 15:44:35 -0500  Failed:1
The following errors have occurred:
1. Job failed with an exit code of 127
Looking at the log it says the following error:
2011-09-22 15:44:35,716-0500 DEBUG vdl:transferwrapperlog Exception for
wrapper log failure from catsngridftp-20110922-1544-brgdcf5d/info/t on
eper.ultralight.org: null
Caused by:
org.globus.cog.abstraction.impl.file.IrrecoverableResourceException:
Exception in getFile
Caused by: org.globus.cog.abstraction.impl.file.FileResourceException:
Failed to retrieve file information about
/raid2/osg-data/engage/scec/swift_scratch/catsngridf
tp-20110922-1544-brgdcf5d/info/t/cat-tyxj0agk-info
Caused by: org.globus.ftp.exception.ServerException: Server refused
performing the request. Custom message: Server refused MLST command (error
code 1) [Nested except
ion message:  Custom message: Unexpected reply: 500-Command failed :
globus_gridftp_server_file.c:globus_l_gfs_file_stat:389:
500-System error in stat: No such file or directory
500-A system call failed: No such file or directory
500 End.] [Nested exception is
org.globus.ftp.exception.UnexpectedReplyCodeException:  Custom message:
Unexpected reply: 500-Command failed : globus_gridftp_server_f
500 End.]
2011-09-22 15:44:35,719-0500 INFO  vdl:execute END_FAILURE thread=0-6-0-1
tr=cat
2011-09-22 15:44:35,720-0500 INFO  vdl:execute Exception in cat:
I manually tried to transfer files of small sizes to and from pads to the
site in question and it worked ok.
The complete log for this run is:
http://www.ci.uchicago.edu/~ketan/catsngridftp-20110922-1544-brgdcf5d.log
Could you kindly study the log and give any clues as to what is going on.
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110922/42390b9c/attachment.html>
