[Swift-devel] persistent coasters and data staging
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Mon Sep 12 14:52:03 CDT 2011
Mihael,
Have you just changed the worker.pl. Asking since I am using a mix of trunk
and 0.93.
worker.pl that I am using is 0.93 .. If only this is changed. I will use it
from trunk.
On Mon, Sep 12, 2011 at 1:56 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Mon, 2011-09-12 at 11:58 -0500, Ketan Maheshwari wrote:
> > After some discussion with Mike, Our conclusion from these runs was
> > that the parallel data transfers are causing timeouts from the
> > worker.pl, further, we were undecided if somehow the timeout threshold
> > is set too agressive plus how are they determined and whether a change
> > in that value could resolve the issue.
> Something like that. Worker.pl would use the time when a file transfer
> started to determine timeouts. This is undesirable. The purpose of
> timeouts is to determine whether the other side has stopped from
> properly following the flow of things. It follows that any kind of
> activity should reset the timeout... timer.
> I updated the worker code to deal with the issue in a proper way. But
> now I need your help. This is perl code, and it needs testing.
> So can you re-run, first with some simple test that uses coaster staging
> (just to make sure I didn't mess something up), and then the version of
> your tests that was most likely to fail?
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110912/75421c97/attachment.html>
