[Swift-devel] persistent coasters and data staging
Mihael Hategan
hategan at mcs.anl.gov
Mon Sep 12 15:01:42 CDT 2011
On Mon, 2011-09-12 at 14:52 -0500, Ketan Maheshwari wrote:
> Mihael,
> Have you just changed the worker.pl. Asking since I am using a mix of
> trunk and 0.93.
> worker.pl that I am using is 0.93 .. If only this is changed. I will
> use it from trunk.
Sorry, but randomly mixing branches means I don't know what code you're
actually using.
Please don't mix things. Or if you do, please be very specific about
what you're using from where.
The worker.pl fix went into the 0.93 branch.
> On Mon, Sep 12, 2011 at 1:56 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
> On Mon, 2011-09-12 at 11:58 -0500, Ketan Maheshwari wrote:
> > After some discussion with Mike, Our conclusion from these
> runs was
> > that the parallel data transfers are causing timeouts from
> the
> > worker.pl, further, we were undecided if somehow the timeout
> threshold
> > is set too agressive plus how are they determined and
> whether a change
> > in that value could resolve the issue.
> Something like that. Worker.pl would use the time when a file
> transfer
> started to determine timeouts. This is undesirable. The
> purpose of
> timeouts is to determine whether the other side has stopped
> from
> properly following the flow of things. It follows that any
> kind of
> activity should reset the timeout... timer.
> I updated the worker code to deal with the issue in a proper
> way. But
> now I need your help. This is perl code, and it needs testing.
> So can you re-run, first with some simple test that uses
> coaster staging
> (just to make sure I didn't mess something up), and then the
> version of
> your tests that was most likely to fail?
> Ketan
