[Swift-devel] 0.93 problem: Fwd: amwg-swift
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu Sep  1 17:35:10 CDT 2011
Can't tell much without a log.
On Thu, 2011-09-01 at 17:32 -0500, Michael Wilde wrote:
> This issue reported by Sheri w the Parvis amwg script looks a lot like
> what Jon reported earlier today. Mihael, Justin, David, Jon: can you
> investigate? Jon, can you repro the problem and send in a jstack?
> ---------- Forwarded message ----------
> From: Sheri Mickelson <mickelso at mcs.anl.gov>
> Date: Thu, 1 Sep 2011 16:20:21 -0500
> Subject: Fwd: amwg-swift
> To: Michael Wilde <wilde at mcs.anl.gov>
> Cc: Andrew Mai <mai at ucar.edu>
> Hi Mike,
> Sorry to bother you with this, but if you have time within the next
> 1/2 hour -45 minutes can you check on a amwg-swift run Andy is trying
> on mirage2.ucar.edu?  He lists all the directories below.  It's trying
> to run, but all swift is doing is ...
> Progress:  time: Thu, 01 Sep 2011 15:17:25 -0600  Initializing:450
> Selecting site:12  Stage in:8
> It's been repeating "Initializing:450  Selecting site:12  Stage in:8"
> for the last 40 minutes.
> He's using swift 0.93.  Is this a swift concurrency issue?
> -Sheri
> Begin forwarded message:
> > From: Andrew Mai <mai at ucar.edu>
> > Date: September 1, 2011 4:09:05 PM CDT
> > To: Sheri Mickelson <mickelso at mcs.anl.gov>
> > Subject: Re: amwg-swift
> > On 09/01/2011 02:59 PM, Sheri Mickelson wrote:
> >> That's not normal.
> > I have to go to a CSEG meeting. I will leave it running on mirage2.
> > You can log in and watch it run, if you want to. Relevant directories:
> > work dir   : /glade/scratch/mai/swift-workdirectory/
> > amwg_stats-20110901-1440-ujv4b5z8
> > script dir : /glade/home/mai/AMWG_diag/swift
> > code base  : /fis/cgd/cms/amwg/amwg_diagnostics_swift
> > output dir : /glade/scratch/mai/output-SO1
> > Andy
