[Swift-devel] 0.93 problem: Fwd: amwg-swift
    Jonathan Monette
    jonmon at mcs.anl.gov
    Thu Sep  1 21:52:48 CDT 2011
I re-ran my scripts with the updated 0.93 source and they completed.  Maybe this workflow was running on an out of data svn revision.
On Sep 1, 2011, at 5:35 PM, Mihael Hategan wrote:
> Can't tell much without a log.
> On Thu, 2011-09-01 at 17:32 -0500, Michael Wilde wrote:
>> This issue reported by Sheri w the Parvis amwg script looks a lot like
>> what Jon reported earlier today. Mihael, Justin, David, Jon: can you
>> investigate? Jon, can you repro the problem and send in a jstack?
>> ---------- Forwarded message ----------
>> From: Sheri Mickelson <mickelso at mcs.anl.gov>
>> Date: Thu, 1 Sep 2011 16:20:21 -0500
>> Subject: Fwd: amwg-swift
>> To: Michael Wilde <wilde at mcs.anl.gov>
>> Cc: Andrew Mai <mai at ucar.edu>
>> Hi Mike,
>> Sorry to bother you with this, but if you have time within the next
>> 1/2 hour -45 minutes can you check on a amwg-swift run Andy is trying
>> on mirage2.ucar.edu?  He lists all the directories below.  It's trying
>> to run, but all swift is doing is ...
>> Progress:  time: Thu, 01 Sep 2011 15:17:25 -0600  Initializing:450
>> Selecting site:12  Stage in:8
>> It's been repeating "Initializing:450  Selecting site:12  Stage in:8"
>> for the last 40 minutes.
>> He's using swift 0.93.  Is this a swift concurrency issue?
>> -Sheri
>> Begin forwarded message:
>>> From: Andrew Mai <mai at ucar.edu>
>>> Date: September 1, 2011 4:09:05 PM CDT
>>> To: Sheri Mickelson <mickelso at mcs.anl.gov>
>>> Subject: Re: amwg-swift
>>> On 09/01/2011 02:59 PM, Sheri Mickelson wrote:
>>>> That's not normal.
>>> I have to go to a CSEG meeting. I will leave it running on mirage2.
>>> You can log in and watch it run, if you want to. Relevant directories:
>>> work dir   : /glade/scratch/mai/swift-workdirectory/
>>> amwg_stats-20110901-1440-ujv4b5z8
>>> script dir : /glade/home/mai/AMWG_diag/swift
>>> code base  : /fis/cgd/cms/amwg/amwg_diagnostics_swift
>>> output dir : /glade/scratch/mai/output-SO1
>>> Andy
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
